2001 V70XC - Switched to Pennzoil Full Synthetic 5W30
- regent
- Has thanked: 2 times
- Been thanked: 12 times
One of my trusted internet myth sources (which I cannot reveal) just confirmed that the M1 and Penn won't mix at all, they will stay separate like mercury in water
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
At the recent oil & filter change, the action of pulling up dipstick was free of any resistance. The two o'ring were dried and cracked so replaced both with Volvo's.
It now takes some effort and seals better. What to expect, change in crankcase pressure etc?
- regent
Yes - only if you have a very neglected PCV system (which I doubt).xHeart wrote: 18 Apr 2018, 08:24 At the recent oil & filter change, the action of pulling up dipstick was free of any resistance. The two o'ring were dried and cracked so replaced both with Volvo's.
You could as well do the Rubber Glove Test and prove me right (or wrong) at any time
2015 BMW 335i
2015 BMW 335i
Your engine will Schmell...dlundblad wrote: 05 Apr 2018, 06:57All current engine oils are compatible. No issue whatsoever.abscate wrote: 04 Apr 2018, 20:00 Just don’t mix Shell and Mobil oils. Either one is fine, don’t mix.
What if someone had Mobil 1 oil, but did an oil change and switched to Pennzoil/ Shell? You can bet the new oil is mixing with what was left in the sump.
Off to carve another notch under my bridge...
- dlundblad
- Year and Model: 2002 S60 2.4t
- Has thanked: 6 times
- Been thanked: 4 times
The mark was well deserved.abscate wrote: 18 Apr 2018, 09:37Your engine will Schmell...dlundblad wrote: 05 Apr 2018, 06:57All current engine oils are compatible. No issue whatsoever.abscate wrote: 04 Apr 2018, 20:00 Just don’t mix Shell and Mobil oils. Either one is fine, don’t mix.
You definitely got me.
Hers: Charcoal 2002 S60 2.4t 187k
- June
- Has thanked: 523 times
- Been thanked: 261 times
Abscate was adding his special humor to the conversation! Once a year oil changes are crazy in my opinion in a old engine no matter what oil.dlundblad wrote: 05 Apr 2018, 06:57All current engine oils are compatible. No issue whatsoever.abscate wrote: 04 Apr 2018, 20:00 Just don’t mix Shell and Mobil oils. Either one is fine, don’t mix.
I use Redline 10W30 in my 2004 S80 T6 which is a group 5 oil, but a estar based product. Even though Ester is supposed to be the most stable base available I certainly won't leave the oil beyond the 6 months Volvo recommends and never the 7500 miles per Volvo either. It seems to me my 14 year old engine has to be allowing more contaminants past the rings polluting the oil than when new. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
The six months is to accommodate the use of mineral oils though. It's never been shorter than a year since at least the 80s over here. A lot depends on driving patterns as well though.
Full disclosure.... that zinger Is from car Talk, the NPR car show by the Magliottzi brothers. ( creative spelling mine)dlundblad wrote: 18 Apr 2018, 19:07The mark was well deserved.abscate wrote: 18 Apr 2018, 09:37Your engine will Schmell...dlundblad wrote: 05 Apr 2018, 06:57
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Agree, 6 months is rather for mineral, a good synthetic should last a decent 12 months and/or 7000 miles in a region with mild climate given the engine runs in good condition.
But the best really is to send an oil sample (for ex to https://www.blackstone-labs.com/ - p.s. I don't work for them). This should put an end to any doubts.
As June said, engine condition is critical for engine oil life. A more or less good working PCV system may cause oil contamination, not to mention a less optimal injector spray pattern (incomplete gas/air mixture combustion), stuck piston rings, clogged VVT solenoids, plenty of things that may cause the engine oil to get contaminated.
- Rattnalle
The purpose of the oil is to get contaminated so that nothing else is
I still don't get oil analysis though. All it seems to tell you is whether you've gotten the engine warm enough to boil moisture and fuel away and if you've got a coolant leak. Both quite easy to tell if you're the one driving the car yourself regularly.
