boost and vacuum piping.
Has thanked: 1614 times
Been thanked: 4078 times
rguzz wrote: 06 Apr 2018, 06:51 Do Something like this, with the wastegate on the car. I use my brake bleeder and it's gauge to test mine. Mityvac should work. Diaphragm was broken, no vacuum, so replaced it with one from Ebay. There are numerous Youtube videos, Robert DIY links to adjusting properly, pretty easy even for me. 4.4 PSI on the rod, if I recall, though I did 6 PSI.
If you are using a gauge like this for the wastegate adjustment start on the low side of the pressure set point, set the rOd, then test drive. Typical error on a gauge will be 5% full scale or 1.5 psi
You don’t want to overboost or you will bend a rod.
I don’t think you are in a much danger with a 99 ME7 as that system monitors manifold pressure
PurpleSnow
Year and Model: 1994 850 T5 sedan
Has thanked: 1 time
Post by PurpleSnow »
got that fixed as well.
what should the standard boost be on the t5
Volvo 850 T5 1994 Still deciding
Subaru legacy Wagon 1993 (Swopped) Problems
VW Jetta mk3 CLX 1998 (Swopped) Rust bucket
VW Golf mk4 2.0 (Seazed) Worst Borrow
VW Golf MK2 GTi 1987 (sold) FUN
VW Golf CTi 1993 (Sold) FUN
Ford Escort Sport 1977 (Sold) Project
VW Bug 1971 (Sold) Worst buy
Ford Escort Sport 1978 (Stolen) Perfect
abscate wrote: 08 Apr 2018, 06:00
And I got this completely backwards.
If you are using a larger scale gauge, start on the
HIGH SIDE OF THEPRESSURE SETTING FOR YOU CAR !!!
PurpleSnow
Has thanked: 1 time
can there be a leak at the vacuum pipes at the pedals because i can hear a hissing noise when i press the brakes. i still have a leak somewhere because i still have a boost drop if i accelerate gradually. it goes up to 0.6 bar and then drops to 0.3 bar.
