1994 850 new Owner Just Arrived, AC stuck on
- Has thanked: 311 times
- Been thanked: 817 times
I've never dropped the trans but I've pulled the engine a few times and its not bad at all if you have space, a hoist and time. Then you can easily d timing parts, check and service all PCV including the passage into the pan, change the OIL PAN O-rings (which are almost certainly needed) and be really thorough on the refresh.
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
As long as the AC cycles as it should, that is thr clutch working and not being stuck, why do anything? One of the best ways to ruin it is to keep it off for too long
- Been thanked: 4068 times
You can either cherrypick the engine and trans up together or lowersubframe and engine and pull the trans underneath.
Oh yes, when I say pull the engine I mean engine and trans together.
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 53 times
How did you pull the mileage on a 94? Just curious. There a connector somewhere that I don't know about? Bc I'd love to have an interface!
Pull the AC fuse, if it still runs the AC clutch is over adjusted and too close. Which is extremely unusual. As it was said before someone probably over adjusted it with ziptie/bread ties. I use guitar picks to adjust my schedule clutches. Much easier to be spot on as they are a more standard thickness.
Can't wait to see your write-ups on pulling the engine!
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
Are you sure the ACclutch is engaged? 50F Cool
Air will feel like AC even if the system is off. Double check by watching the outside of the AC clutch and see if the flat face is spinning ( on) or not ( off)
These cars turn on the AC automatically if you select defrost mode ( true for 94?) so if that linkage is misadjusted that could be commanding full time AC
You should also check the cabin temp sensor. Look above your head on the headliner above the door and clean the junk out of the fan, search here for test data on the cabin temperature sensor specs
ir637113
- Year and Model: 94 850 NA Wagon
- Has thanked: 12 times
Out of curiosity - how do you check this? I have a 94 850 Wagon I'm trying to sell, and the odometer has been stuck on 127 since we bought it. Would be kinda cool to find out how many miles this thing actually has (our guess is 200k, but who knows)
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
ir637113 wrote: 16 Apr 2018, 07:09Out of curiosity - how do you check this? I have a 94 850 Wagon I'm trying to sell, and the odometer has been stuck on 127 since we bought it. Would be kinda cool to find out how many miles this thing actually has (our guess is 200k, but who knows)
- 156 Views
- 15 Replies
- 1003 Views
Last post by foggydogg
- 1524 Views
Last post by precopster
- 11 Replies
- 2650 Views
Last post by dorvin
- 1270 Views
Last post by dubsetter
