2000 V70R Possible Burnt Valve - looking for advice
configsys
Year and Model: V70R
Has thanked: 2 times
Been thanked: 5 times
Post by configsys »
abscate wrote: 16 Jun 2018, 19:27 Check the helper forum for any SLUTs nearby for moral support.
That didn’t write quite like I meant
With the uncertainty and everything going on with that vehicle, I needed that laugh - too funny :P
'16 S60 AWD
'17 S60 (totaled)
'13 XC60 Polestar
'12 S60 T5
'04 XC90 (sold)
'02 S40
'00 V70R
'93 850 GLT (sold)
'13A DICE/VIDA
Has thanked: 2199 times
Been thanked: 1852 times
There is always this option, but watch out for rear sub-frame corrosion.
viewtopic.php?f=6&t=78569&p=474481#p474481
configsys
Post by configsys »
Ordered an endoscope camera on Amazon. Will use it to verify the damaged burnt valve. In the meantime, been spending a lot hours on Youtube of Robert's DIY on the preparation, removal and install of the cylinder head. I'm trying to figure what else I should do when I finally tackle the job (timing belt, water pump, PCV system, etc.).
'16 S60 AWD
'17 S60 (totaled)
'13 XC60 Polestar
'12 S60 T5
'04 XC90 (sold)
'02 S40
'00 V70R
'93 850 GLT (sold)
'13A DICE/VIDA
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
configsys wrote: 20 Jun 2018, 12:51 Ordered an endoscope camera on Amazon. Will use it to verify the damaged burnt valve. In the meantime, been spending a lot hours on Youtube of Robert's DIY on the preparation, removal and install of the cylinder head. I'm trying to figure what else I should do when I finally tackle the job (timing belt, water pump, PCV system, etc.).
Camshaft seals (you're already going to have the head off anyways)
+1 on everything you already listed
New timing belt tensioner
New timing belt idler pulley (not sure about the timing setup on the 2k, I only have a 1999)
Check the motor mounts since you're already going to be in there. I believe the rear mount may be easier to replace with the head off, but don't quote me on it as I haven't done this job myself yet.
Replace any and all rubber hoses you can get at - heater hoses, radiator hoses, turbo, you name it. Anything with coolant or oils running through it.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
+1 to all the above. That's pretty much all I'm doing on my R while I do the M56 swap.
2000 timing belt tensioner is the same as '99, the mechanical tensioner.
