1999 V70T5M56 Rear Bumper Bracket Replacement 6816114 and shock cup 3546435
Has thanked: 1610 times
Been thanked: 4068 times
abscate wrote: 26 Jun 2018, 09:21 On edit - there is a much better write up on this by Jreed here ( sorry aboutghosting you earlier Jason)
viewtopic.php?f=1&t=49802
Rattle rattle rattle goes the rear bumper.
Ive noticed it is loose, and rolling underneath, the salt has eaten away the steel brackets that mount the Aluminum member to the frame rails.
I managed to string a heavy zip tie around the top of the rails, and then through the member to hold in place.
Correct way to fix, parts on order, will be
4 each 988182 986504 Flange Screw
2 982831 Bracket screw
2 6816114 Brackets
Fixed VRD REFERENCE. Jason did the awesome write up , upthread. There is info on drilling drain holes in that thread m too.
The 10 mm head bolts referenced in these threads aren’t used on later cars, 1998/99
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
scot850 wrote: 12 Jul 2018, 11:23 I hope after all that work you went to the effort of protecting all that rusted rear metal the bumpers mount to like this:
That painted bumper bracket area is lovely. Why did you repaint it? I'm curious to see the "before" pictures. I'm replacing my bumper so might also take these preventative measures.
FireFox31
Has thanked: 2203 times
Been thanked: 1852 times
It was more to do with rust starting to appear and as I was in there with clear space and access seemed crazy not to protect it.
