First step is to check the timing, which can definitely be done in the garage with a few tools and jack and jackstands. This involves jacking up the car, pulling the passenger wheel, removing the plastic over over the timing belt, and checking out the timing market in three places. Look up some videos and check the pdf I linked to up above. If checking the timing is daunting then it needs too go to a shop, fixing the timing follows up on the check and gets more complicated. It is all described in the first link I gave you.Mr. Detail wrote: 08 Jul 2018, 08:59 Thank you "erikv11" for your two responses.
On your "P0012" comment, if the cam timing is off a tooth as you stated, is that going to be a dealer fix? I try to avoid the dealer unless absolutely necessary. I did see a video for replacing what the guy called a "cam timing sensor" which in the video was an easy replacement. It was a plug 'n play type part right on top of the engine.
2002 V70 CEL codes P0012 P0442
- Has thanked: 311 times
- Been thanked: 817 times
- 4267 Views
Last post by Smirniy
- 13 Replies
- 5027 Views
Last post by SuperHerman
- 1962 Views
Last post by vtl
- 11 Replies
- 70 Views
Last post by Georgeandkira
- 1253 Views
Last post by zwieback
