I'm getting code P0442 and want to check the J-Hose since that seems to be a likely culprit.
There are several conflicting instructions where exactly the charcoal canister and J-Hose are located but it sounds like the 2002 V70 2.4 (non-turbo) might have it behind the rear driver side wheel.
Can anyone confirm?
Thanks,
Andrew
2002 V70 2.4 Where is J-Hose (code P0442)
Hi Andrew
not 100% sure of the V70 but in a S60 2.4l non-turbo was located on the rear subframe in the center.
had to lower the muffler in order to get access to it, hope it helps good luck.
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
Thanks, I'll try getting to it tonight and I'll post back when I find out...Vovo_merz wrote:Hi Andrew
Yup, it's in the rear center and after taking off the left rear wheel it's easily visible. My J hose was cracked so I'm guessing that's the cause of the code.Vovo_merz wrote:Hi Andrew
- 800 Views
Last post by RickHaleParker
- 2179 Views
Last post by jbkeene
- 2452 Views
Last post by erikv11
- 638 Views
Last post by jreed
- 666 Views
Last post by jcdillin
