Agreed. Is there a better way to check injectors than a test light? I have pressure at the rail, and good readings on cam and crank sensors per Chilton/Haynes and a couple of older posts on this siteprecopster wrote: 09 Jul 2018, 00:50 The fact it starts on starter fluid means it has to be a fuel issue.
1998 S70 T5 turned into a brick
dspran
- Year and Model: 1998 S70 T5
- Has thanked: 1 time
- SuperHerman
- Been thanked: 207 times
In what manner did you confirm you have fuel pressure? How did you confirm your pump is working? Have you put a fuel pressure gauge on the fuel rail?
Dumb question - how long has the fuel filter been in service? Could you have messed something up here?
Can you flush out with more detail your testing of the tank to fuel rail delivery?
dspran
Fuel filter is very close to new. This is the only shoddy troubleshoot that has been done, pressure was checked at the fuel rail with the tip of a screwdriver first, convincing me I had good pressure. Not having a fuel pressure gauge I checked it with a tire pressure gauge. I know it’s not ideal but I’ve got 45ish if I recallSuperHerman wrote: 09 Jul 2018, 12:37 In what manner did you confirm you have fuel pressure? How did you confirm your pump is working? Have you put a fuel pressure gauge on the fuel rail?
- SuperHerman
Could be an immobilizer issue - on the later models more common. Not sure how to verify.
dspran
Talked to a local euro car repairer, he suggested maybe the chip in the key was expired, to try spare key. Did so, no change. Pulled key switch apart and cleaned contacts, got the alarm to go off after everything was put back together. Lol no change there either. Everything I see says immobilizer wasn’t used on the 98. This weekends plans are to start over from the OP. Put it back in the air and check anything that was touched for the half shaft/brakes and then verify readings on all the sensors. I have verified the sensors are reading right, but maybe those values aren’t making back to the computer due to bad circuitry. I hate to throw this car away so I’m going to have to keep digging. It will have to involve a scanner that provides live data. My thought is if the computer isn’t getting the signals I am getting, either I have a bad wire or the computer is junk. It has been to doggone hot to spend much time looking into it. I appreciate all the responses and will update when I come up with something conclusiveSuperHerman wrote: 11 Jul 2018, 18:20 Could be an immobilizer issue - on the later models more common. Not sure how to verify.
Definitely you have an immob on a 1998Everything I see says immobilizer wasn’t used on the 98
- SpookyDuchess
- Year and Model: 2000 S70T5
Hey there, this is my first post, as i have been lurking for quite a long time here. Anyway, i used to have a 96 850T5 that would do that exact thing, and also had a 99 S70T5 that would start fine until it got to operating temp, then would not start again until completely cooled off, but would start with spray assistance. Point being, in BOTH cases it was the FPR. The fuel pressure regulator was the last thing i replaced the first time it happened with my 850 wagon, but, the second time with the S70, i replaced it second after the fuel pump. Have you checked your FPR?
dspran
The only thing I see resembling a fpr is on the passenger side of the fuel rail, underneath, and it doesn’t appear to have a lines or wires going to it, just plugged into the rail.SpookyDuchess wrote: 13 Jul 2018, 12:54 Hey there, this is my first post, as i have been lurking for quite a long time here. Anyway, i used to have a 96 850T5 that would do that exact thing, and also had a 99 S70T5 that would start fine until it got to operating temp, then would not start again until completely cooled off, but would start with spray assistance. Point being, in BOTH cases it was the FPR. The fuel pressure regulator was the last thing i replaced the first time it happened with my 850 wagon, but, the second time with the S70, i replaced it second after the fuel pump. Have you checked your FPR?
After retracing my footsteps, I’ve got battery voltage at both 2 and 3 on the cam position sensor wiring. 2 should be around 5 volts? 35 ohms on pin one. Naturally with the key on
- misha
- Has thanked: 155 times
- Been thanked: 432 times
That is a fuel pressure damper.dspran wrote: 15 Jul 2018, 12:57 ...The only thing I see resembling a fpr is on the passenger side of the fuel rail, underneath, and it doesn’t appear to have a lines or wires going to it, just plugged into the rail.
Fpr is somewhere in steering rack area or behind passenger side rear wheel...around fuel filter...depending which engine management the car have.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
dspran
Update: Went to the local salvage yard today and grabbed a handful of relays and the ecu. Ecu made no change, changed out the relay(timing advance)? driver side above the radiator, I finally got a sputter, then nothing. I was like WTF? Traced vac lines, found one on the back of the engine, driver side. It was deteriorated, I spun it 1/4 turn and the brick fired, ran smoother than ever before. I will be replacing said vac line. I appreciate all the comments and advice. If there is a Volvo Master Tech out there that can comment on this, that would also be appreciated. Someone, sometime will google this and it may help them along the way.
- 14 Replies
- 867 Views
- 2266 Views
Last post by esl_97_850_T5
- 26 Replies
- 5284 Views
Last post by rguzz
- 15 Replies
- 2129 Views
Last post by BlackBart
- 711 Views
