A tools show off thread... ?
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Computer Safe Automotive Logic Probe.
Attach clips to starter battery. Touch tip to point to be tested.
If the tip is high ~12V (Hot) the led lights Red.
If the tip is low ~0v (ground) the led lights Green.
Active
Past
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Another one of my favorites as far as Harbor Freight stuff, I recently picked up a 1/4" Pittsburgh Pro slim head ratchet because my Craftsman 75 tooth began seizing up (6 months old!) and I'm glad I did! It's incredibly smooth and built really well. It holds sockets nice and tight and the length of the handle is perfect. Their pro series (red/black comfort grip) ratchets are some of their best tools. It's definitely my new favorite 1/4" ratchet!
My only complaint is the directional switch is very easy to move, which could be problematic in tight spaces when it could knock against something. It sticks out too much, which I don't like. At least they made it so it swings further up in either direction to avoid accidental movement (something they don't do with their quick release chrome ratchets) but it only does so much. The switches on my Duralast ratchets are much better.
https://www.harborfreight.com/14-in-dri ... 62329.html
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
Why is "Tool #4" in the Volvo timing tool kit needed? They press against the valve springs so the cam cover goes down square?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Ratchets that reverse direction because of a poorly designed switch are the worst.
Also -> Amazon link
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
bmdubya1198 wrote: 09 Sep 2018, 07:51 My only complaint is the directional switch is very easy to move, which could be problematic in tight spaces when it could knock against something. It sticks out too much, which I don't like.
nothing a grinder cannot fix - speaking about the bump on the switch 8)
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
Georgeandkira wrote: 09 Sep 2018, 09:01 Why is "Tool #4" in the Volvo timing tool kit needed? They press against the valve springs so the cam cover goes down square?
Yes, to help it go down evenly. I also suspect it makes things a bit easier on all the cam cover bolts if you aren't actually relying on them to push the cam cover and valve springs down. I didn't have this when I did my cam cover jobs, so I just relied on the bolts to do the pulling together, but I would have rather used it.
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
RickHaleParker
Yes #4 works against the valve springs and lifters.
1. Holds the cam cover true to the head.
2. Spreads the liquid gasket evenly.
3. Locks the O-rings in place.
4. Vertically aligns the holes in the head with the holes in the cam cover, minimizing the odds of cross threading.
5. Facilitates even torquing of the bolts across the cam cover.
If you install the cams to the cover using #2 & #3, the valve springs and lifters pressure against the cams and cover is at the minimum and the camshafts are aligned. Do this with the crankshaft aligned and you need not worry about bolting down the cam cover with the timing in an interference condition. Everything will go together aligned and in time.
Active
Past
bmdubya1198
oragex wrote: 09 Sep 2018, 11:09 nothing a grinder cannot fix - speaking about the bump on the switch 8)
That is true!
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
Low profile ratchet from HF.
It fits where most dont.
Not comfortable in the hand but a blessing when you gotta have it.
Both 1/4 and 3/8th ends, flex head, button release.
bmdubya1198
I've heard good things about that low profile ratchet. A HF gem. That's one I'd like to get at some point.
