T5M bogs when getting off the gas
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
alright. if it takes that long i might just pour a bottle of injector cleaner into the fuel tank and drive. and maybe replace the fuel filter. most probably still the original one.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- misha
- Has thanked: 155 times
- Been thanked: 432 times
That's is NOT good....it should be replaced between 50-100k km.Clemens wrote: 12 Oct 2018, 11:11 ... and maybe replace the fuel filter. most probably still the original one.
That's how i'm doing it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
I missed this on previous reply...are turbo models have intake air temperature sensor(IAT sensor)?Clemens wrote: 12 Oct 2018, 10:08 ...edit: what's left feels basically like small misfires at steady rpms between 2 and 3k. Snooth under boost, alright when getting off the gas
If not....i'm guessing that you have small vacuum leak somewhere.
I'm assuming that you don't have DTC stored or pending.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
No CEL. I had one showing a long term fuel trim issue when I bought it 2 years ago. After deleting it, it never returned. I searched for leaks thoroughly, couldn't find any. Maybe around the fuel injectors. would it be safe to spray the fuel injector seals with brake cleaner?
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- misha
I'm not sure about brake cleaner onto injector's o-rings.
What about IAT?
What about IAT?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
from what I have read only cars 99 and up have that sensor. i will doublecheck tomorrow and try to read if any codes are stored even though no cel is on
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- misha
Being a '94 you will have just obdI diagnostic ports under the hood.
Some codes will not turn on check engine light but they will be stored in ecu fault memory.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
no codes stored in A2 (fuel system) and I can't get a signal from A6 (ignition) from the blinky box.
the lighter the throttle input, the worse it is. gotta look for vacum leaks again
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- misha
If fuel filter isn't replaced recently,like you said....i would replace it first.
What about spark plugs...being a turbo car....are they properly gapped?It is pretty important for turbo engine.
Ignition ecu should be also scanned for codes...could be that there is a problem...somewhere...and CEL being OFF doesn't necessarilly mean that there are not codes stored.
Maybe IT is the source of the problems you're experiencing.
That said....not being able to communicate with it....could be that there is a problem.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
plugs are new volvo, gapped correctly. maybe ignition wires. the ones on my 95 na went bad after 19 years, the ones on my 96R after 20. in this car they are from 94, one being a different length, looks like from the junkyard or sthg.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 23 Replies
- 7623 Views
Last post by MrAl
- 1196 Views
Last post by alschnertz
- 22 Replies
- 2440 Views
Last post by Holiday
- 2026 Views
Last post by pbierre
- 956 Views
Last post by cn90
