Volvo 98 S70 Dipstick Tube replacement and tools required
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Be carefull on oil dipsticks because there are two versions depending on crankcase capacity.
One is red and the other one is fluorescent.
Difference is in about 1liter of oil.
Red...between min and max 1l of oil is needed.
Fluorescent...between min & max 1.5l of oil needed.
Dipstick tubes are also not interchangeable between those two dipstick colours.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
Nothing takes 10 minutes to do, basically. The bolt is a little tricky to get to IIRC, and you need a few angled tools to facilitate removal. Be careful not to cross thread when installing. Clean it up well. Don't do it before you have to pick up your kids or rush anywhere, though pretty easy like everything takes a few. Seat the dipstick tube well before tightening down, use a little lube or grease to facilitate. Watch for leaks after!
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
rguzz wrote: 14 Oct 2018, 06:33 Nothing takes 10 minutes to do, basically. ...
+12,337,987
My favorite are the posts titled "DIY Fix problem x for only 15 minutes and $4.37!!!" where you need $80 in tools (and that's Harbor Freight rates) just to get started.
In 10 minutes you can walk out the back door, open the garage, pull the car in and open up the tool box.
rguzz
Post by rguzz »
