Inherited 2002 V70 X/c. Failed turn signal switch, battery drain Topic is solved
OregonVolvo
- Year and Model: 2002 Volvo V70 T5
- Has thanked: 1 time
Did the replacement of the turn signal switch solve the BATTERY DRAIN issue?
OregonVolvo
Mike Langlois wrote: 25 Nov 2018, 04:08 Yes, high beams were randomly turning on. Switch was obviously broken and should have been the first thing I checked.
- Mike Langlois
- Year and Model: 2002 V70 & V70 XC
- Has thanked: 28 times
- Been thanked: 6 times
Yes; the issue was a damaged switch. I checked EVERYTHING else before dealing with the obvious!! No check engine lights or trouble codes and the battery holds a charge.
OregonVolvo
Thanks Mike ! I have the exact same issue with my 2002 V70 wagon. The high beam feature of the turn signal switch is broken, allowing the high beam relay to be energized, even when the key and engine is turned off... thus allowing the battery to drain overnight!Mike Langlois wrote: 01 Feb 2019, 17:58 Yes; the issue was a damaged switch. I checked EVERYTHING else before dealing with the obvious!! No check engine lights or trouble codes and the battery holds a charge.
- Mike Langlois
We pulled the high beam fuse to keep the car running.
- 11 Replies
- 1928 Views
Last post by plumsmooth
- 983 Views
Last post by Metallo
- 1368 Views
Last post by ggleavitt
- 1622 Views
Last post by boostedxc
- 3305 Views
Last post by firstv70volvo
