Kudos to you for stopping BEFORE you stripped them out and reorganized the troops for attack.
These are the times quality tools pay. Harbor a Freight, craftsman by Lowes, Kobalt need to be put away and a real tool purchased. Get a brand new Torx bit from a upbrand like Mac or Snap on, get it seated on the head, apply penetrating oil like Kroil, ZpB Blaster, Liquid a Wrench, not WD40 and give it 99 light raps with a small hammer. You are trying to work the penetrant down the threads, not mar the fastener. Light taps like just letting the weight of the hammer fall by 15 cm or 6 inches
I love the write up on stuck fasteners from Colin Kellog, the Itinerant Air Cooled Mechanic
http://www.itinerant-air-cooled.com/vie ... hp?t=13481
Thermostat Replacement Advice
- Has thanked: 1613 times
- Been thanked: 4078 times
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
It pays to have a brass hammer for this if you have trouble with self control.abscate wrote: 17 Nov 2018, 23:49 Kudos to you for stopping BEFORE you stripped them out and reorganized the troops for attack.
Knows enough to be dangerous
- Has thanked: 312 times
- Been thanked: 818 times
Thread is M6. Length I am not sure, measure one?callahanoffroad wrote: 17 Nov 2018, 16:44Any idea what size bolts they are?WhatAmIDoing wrote: 17 Nov 2018, 16:05 I've heard of using a dremel with a cutting wheel to cut slits into the bolt heads for removal with a large flat head screw driver.
I do not think these are common bolts to snap, usually just strip the heads, so I would try the impact. But first, soak everything in your favorite penetrating oil. Also, you are 100% going to want new, quality steel bolts.
Cam cover bolts work perfectly. I've got few dozen of them ...
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
Length of entire bolt is 1 3/8", threads 1 3/16", head 3/16".
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
vovo850
- Year and Model: 1995 850 glt
- Has thanked: 49 times
covering with something works quite well, I too have a stripped bolt and while I keep meaning to get to it, I haven't yet.wizechatmgr wrote: 17 Nov 2018, 18:47All else fails, cover half of the front of the radiator with cardboard until you can get it off - any heat that is more than you have will be heat you appreciate.callahanoffroad wrote: 17 Nov 2018, 18:44That's the, I'm taking my ball and going home scenario.wizechatmgr wrote: 17 Nov 2018, 18:41 Worst case scenario - I believe the whole housing can be removed from the engine. Obviously this too isn't fun...
I believe I shocked my bolts with a couple pound sledge on the end of a 3/8" extension before I removed them.
I bought my new bolts at the dealership. Doesn't matter where you get yours though, they all should be the improved steel.
I actually use "fanfold" it's styrofoam they use to cover houses for insulation before vinyl siding it.
It doesn't break down like cardboard does.
Not practical to go buy it for just that purpose, but if you pass up a siding job I'm sure the
guys would give you scrap piece that will fit.
From my understanding it isn't that the bolt is stuck, it's the heads are soft.
I've seen videos where they basically snap the head off and than use vicegrips to turn the bolt out.
1995 Volvo 850 GLT N/A automatic wagon
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- rspi
Contact rspi..
- rspi
Contact rspi..
- rspi
Contact rspi..
The Volvo repair manual says that the pin should be at 1 O'clock when installing the thermostat.
- rspi
Contact rspi..
- 841 Views
Last post by oragex
- 3819 Views
Last post by oragex
- 2043 Views
Last post by F250
- 19 Replies
- 1947 Views
Last post by configsys
- 540 Views
Last post by Masscomguru
