Try to re-seat ecu...or check for corossion on contacts.
Since cleaning and re-seating 02 sensor's connector cured the problem for a while...it seems that you are on the right track.
I would check o2 connector from the wiring harness side...and try to minimize the gap between the pins with a small precision flat screwdriver.
94' Volvo 855T P0131 after a new O2
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- henrysin44
- Year and Model: 1994 Volvo 855 Turbo
- Has thanked: 2 times
- Been thanked: 3 times
Well the wiring seems fine, picked up some carb cleaner to see if I might have a hidden vacuum leak somewhere and found one at the base of the vacuum tree and the brake booster hose(fixed), carb cleaner managed to stall the engine finding it. I'm going to order a new tree seal from a local place tomorrow but I still find it hard to believe a vacuum leak would give a P0131.
Daily driver Black 1994 Volvo 855 2.3L Turbo - manual swapped, turbo swapped, green injectors, custom M4.4 Tune, de-catted, custom two-tone interior, V70R seats & rims
Teal 1994 Volvo 855 2.5L N/A Manual Transmission (the back up daily and parts car) - Runs and Drives but the engine knocks
Silver 1997 Honda CRV 2.0 AWD - its in a very sorry condition, but drives
Silver 2003 Subaru Forester 2.5L N/A AWD - Leaks everything
- henrysin44
One thing I forgot to mention is the car runs terrible until warmed up, idle drops and recovers, sluggish and feels like it will stall out, once warmed up it runs great. This would happen before the car started acting up and tossing a P0131. Wondering if maybe the coolant temperature sensor would do any of that and be a contributing cause to the P0131.
I've been searching the net about this problem and found an old forum post I made here and this was happening with the old sensor, replacing it solved the problem.
- misha
Usually...ECT will throw it's own dtc...not o2 sensor dtc p0131.
Since the sensor is oem Bosch,i would say that wiring harness side of connector is bad...especially since the code is intermittent.
Clearing the gaps on connector with precision small flat screwdriver might be the best solution.
O2 sensor fault will not participate in idle problems you have.
Bouncing idle is more of a bad MAF problem or it's connector since they are prone to failure..BUT that doesn't fit in o2 sensor dtc.
You mentioned that you have flashed ecu installed...maybe it's at fault.
Stock ecu would be the best start...in order to rule out the flashed one.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- henrysin44
I'll give the gap clearing a try, I've inspected all wiring in the engine bay and tested continuity from the O2 all the way to the ECU and everything checks out. I did put the original M4.3 back in and it had no change, P0131 would still come up. Oh and the code isn't intermittent anymore, comes up 2 minutes after clearing. Unless a faulty MAF sensor could do this I can't find anything that could cause the O2 sensor to do this.
- misha
You would get a maf dtc....but try to reseat it's connector few times and also check gaps on it's pins too.
I had a bad maf connector(gap between pins) which i fixed with small precision screwdriver...tapping them closer to each other the best i could.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- henrysin44
I tightened the gaps between the pins of the MAF, O2, and ECU connector. Still no change, i'm still waiting on the vacuum tree O-ring but i'm not too hopeful it will clear the code.misha wrote: 31 Dec 2018, 08:25 You would get a maf dtc....but try to reseat it's connector few times and also check gaps on it's pins too.
I'm also still getting long starts, and running terrible when cold started, feels like the car will stall out and no power until operating temp....I feel like its connected to whats causing the O2 sensor code
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Remember that the IC is "supposed" to leak air out through the bottom. If you have other leaks in it, they're usually quite easy to find. A smoke test is also pretty simple to set up if you're only testing the IC, but plug the hole in the bottom before you blow anything into it.
You said you have a rear O2 sensor - have you replaced both of them, then, or just the one? Your symptoms sound like a shot MAF and O2 sensor combined to me, but the coolant temp sensor can definitely contribute. If the ECU thinks the engine is at a different temp than it really is (in your case, thinking it is already warm, it seems), it will make terrible decisions, not put on socks and run around without a good jacket.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- henrysin44
I replaced the vacuum tree gasket and the car is now vacuum leak free, but the code still comes back, although the car drives fine when the code is set now. However over the summer I cracked the thermostat housing (bottom) by over-tightening the top housing bolts, I replaced the whole housing with one from a 2000 V70R, my 850s ECT sensor wouldn't fit in it so I wired up the larger thread V70 sensor to it.
I found the ohm values are different with the V70 compared to the 850 although the gauge rests at 3 o'clock where it should. Worth looking into?
850 V.S V70 ECT values: viewtopic.php?t=79330
Sommerfeldt
Yes, it is worth looking into.
If your V70 ECT is telling the ECU 300 ohm, the ECU thinks the engine is at 80 degrees, even though the ECT is saying it's at 40.
They're like a Swede and Norwegian talking to eachother. The Norwegian says something is "rolig". The Swede thinks something's funny, but the Norwegian is saying something's calm.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- 1408 Views
Last post by henrysin44
- 766 Views
Last post by misha
- 413 Views
Last post by Sveedy
- 2271 Views
- 811 Views
