Car dies while driving
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
940tvolvo
Year and Model: 1991 Volvo 940turbo
Has thanked: 1 time
Re: Car dies while driving
Post by 940tvolvo »
Thank you- would the car sound like it is getting no compression? And would the car just die suddenly and not restart? Sorry, but I am a woman who learned the little bit I know from my ex, so I am just trying to figure it out best I can without spending a lot of money.
Thank you again very much appreciated.
940tvolvo
Has thanked: 1 time
Post by 940tvolvo »
Also, when car die there were no unusual noises.
940tvolvo
Has thanked: 1 time
Post by 940tvolvo »
One more thing and I am not sure this has anything to do with the current problem, but sometimes my alternator & bulb failure warning lights come on when I press on the break. But as soon as I let off the break the lights go off. However, it only does it sometimes. Sorry as I am sitting here I keep thinking about it and thought I should include everything I can b/c maybe it's relevant.
940tvolvo
Has thanked: 1 time
Post by 940tvolvo »
would car backfire with a slipped timing belt?
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
940tvolvo wrote: 08 Jan 2019, 20:41 would car backfire with a slipped timing belt?
Yes it could. A slipped timing belt would knock the engine out of synchronisation. Valves open at the wrong time.
Take the plastic cover off the top of the engine. The timing belt is at the front under the cover. Press down on the timing belt, it should not move then about 1/4 inch.
dj_v70
Year and Model: v70 2003
Has thanked: 7 times
Been thanked: 23 times
Post by dj_v70 »
Did you try the starting fluid as earlier suggested? It is more likely a fuel delivery issue than a timing belt issue. If car is back firing, hold peddle to floor while starting and rev engine up a bit if the car starts to clear engine of excess fuel.
Alternator issue is not related to issue of getting a car started with a charged battery.
940tvolvo
Has thanked: 1 time
Post by 940tvolvo »
my roommate said he tried with starting fluid, but no i am not sure i am going to go try right now. thank you so much
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Could this car be a 1991 940 SE?
1988 Volvo 760 Turbo Wagon
dj_v70
Post by dj_v70 »
Just to be clear, if the car doesn’t start at all without starting fluid and itstarts for a few seconds and then dies when using starting fluid, that means that you have a fuel delivery problem.
RickHaleParker
940tvolvo wrote: 10 Jan 2019, 10:42 my roommate said he tried with starting fluid, but no i am not sure i am going to go try right now. thank you so much
Three second shot of starting fluid and no more, into the air intake hose , one Mississippi two Mississippi three Mississippi stop spraying and crank the engine over . Too much can blow it sky high.
