Damaged engine block?
- RickHaleParker
- Been thanked: 978 times
Active
Past
Past
That can’t have 24 valves, it doesn’t say DOHC on the cover
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Don't be silly. It's 24 at either end. 56 in total, in other words.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- June
- Has thanked: 523 times
- Been thanked: 261 times
Why you didn't mention it takes two mechanics to add oil! One on the right and the left... June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
What holds the oil filler spout in place? Pressed/threaded/glued??
I seem to recall a thread ~3 years ago... it was either theorized or discussed that overheating the engine fatigues the metal on this plug, or the hole it's pressed into, so that it looses it grip and can pop up even without a crankcase pressure issue. Merely tapping it back down leaves you in a situation where it could pop completely out while driving creating a mess + fire hazard.
If this plug has begun to push out or deform it needs to be replaced, but attention may need to be paid as to why the original plug did this to begin with. If the hole is damaged/widened the new plug may not stay either without measures such as special glue /spot welds etc.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
that's hilarious!abscate wrote: 04 Feb 2019, 23:17 It's Volvo Yin/Yang
If your VIN starts with Yin, the oil filler is in front. If it is Yang, the oil filler is also in front.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Sommerfeldt
It's a pressed on "sleeve" - don't know if it's glued or not, but the part was available to buy separately once upon a time...mrbrian200 wrote: 05 Feb 2019, 12:16 What holds the oil filler spout in place? Pressed/threaded/glued??
The cap is still available, as far as I can tell, but I think it's inserted from underneath, not from above. So it's not exactly a 2 minute job. Should be possible to do without ripping too much stuff apart, though. Keep the timing belt on, and nothing will move in there.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Has thanked: 311 times
- Been thanked: 817 times
Actually, it seems unwise to remove the cam cover without first removing the timing belt, unless you use cam tools to secure the rear of the cams to the head.
If you leave the belt on and just pull the cover, then the sprocket ends of the cams won't go anywhere, but due to pressure from the valve springs the back ends of the cams will pop up, this will likely crack the front cam guides/slots in the top of the head. You can then pretend it didn't happen and put it back together and maybe be fine but ...
Sommerfeldt
Good point. Better safe than sorry, too. Do what Erik says!erikv11 wrote: 06 Feb 2019, 00:19 Actually, it seems unwise to remove the cam cover without first removing the timing belt, unless you use cam tools to secure the rear of the cams to the head.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
