Low Boost, TCV Adaptation 2000 V70R
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
ndphotonl wrote: 07 Apr 2019, 04:29 Do you have the OEM part number for this?
Should be 9473212, me thinks.
- S
[Sold] '97 S70 T5
ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 27 times
Been thanked: 33 times
Post by ndphotonl »
Thanks!
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
I don't have a Volvo PN for this particular TCV, but the Pierburg PN is 7.22908.03.0.
ndphotonl
Post by ndphotonl »
That looks right, thanks!
https://www.ebay.com/itm/283442478117
Electric control valve (12V) PORSCHE 911, CAYENNE, PANAMERA; ROVER 75 1.8-4.8 06.00-
FlickR images
bmdubya1198
ndphotonl wrote: 07 Apr 2019, 08:08 That looks right, thanks!
That's the one!
ndphotonl
Post by ndphotonl »
Putting it on my order list :)
FlickR images
bmdubya1198
So I decided to check my CBV with a vacuum pump yesterday, and at 15 in-hg, it slowly bleeds dust to 0 within 25-30 seconds. I know the diaphragm is good, but I have heard of the cover being warped and unable to seal. Is this normal behavior for the CBV or is it leaking?
Overall the symptoms I’ve experienced this whole time point to either the TCV or CBV, so I wouldn’t be surprised if that’s the problem.
Sommerfeldt
What happens if you pressurize it? I’m not sure vacuum testing it tells you much - it’s supposed to “let go” when the manifold has vacuum instead of pressure, right?
My CBV, with an iPD HD unit in it was definitely leaking around the edges though, and the piston style new one is very tight indeed.
- S
[Sold] '97 S70 T5
bmdubya1198
I have not tried pressurizing it, my old Mac cooling system pressure tester that I use for that stuff blew out the last time I used it. I did, however, test the CBV on my GLT in the same way and the results were the same, so I assume it's fine.
I believe that's how it works though, when the engine goes into vacuum it releases excess boost pressure.
Has thanked: 1609 times
Been thanked: 4064 times
Dumps all boost pressure on high vacuum.
