Bad?
No codes on Vida Dice or OBD2 reader. Recently cleaned VVT (and new gasket) to fix issues with erratic power and idle. It's happy for now...no codes but still little to no boost out of a T5
Cannot find any leaks, idle is solid.
Where next?
2001 V70T5: little to no boost...how do you know when TCV is
carboncow
- Year and Model: 2003 XC70 2018 S60
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
Probably try disconnecting and plugging the boost hose from the TCV to see if anything changes
Other than looking at the drive signal to the TCV with an oscilloscope or hooking up a boost gauge. it's pretty hard to diagnose TCV .
I believe there are many inputs into the ECU which will inhibit boost or reduce it
carboncow
Thanks. I did have the TCV off to make sure the unit was clean as well as the hoses to each location.
Are you suggesting by passing the unit and direct connecting two hoses together to simulate the TCV engaging? If so which two hoses?
I can pull the TCV off another car if needed and swap out.
I would assume that any of the other inputs that would inhibit boost would show up on Vida/Dice with some type of code, no? Disconnecting the TCV does in fact trigger a code.
The ONLY code I have currently showing up in the O2 sensor on top of the cat. This issue has been there for years and the boost issue is relativity newer.
Thanks.
Thanks.
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
- 1582 Views
Last post by carboncow
- 11 Replies
- 1544 Views
Last post by erikv11
- 1558 Views
Last post by CleanGreen98
- 3111 Views
Last post by vtl
- 21 Replies
- 5330 Views
Last post by bmdubya1198
