2007 V70 R Topic is solved
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Tex69 wrote: 10 Apr 2019, 09:21 What is the 4C suspension? Is that the computer controlled suspension that allows for the three modes?
Continuously Controlled Chassis Concept (CCCC, Four-C or 4C)
Yes it has three modes, Comfort, Sport and Advanced.
Active
Past
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
There is a secret code hidden in the 4C name, hold down the shift key on your keyboard while you type 4C ...
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 57 times
Been thanked: 39 times
Post by EngineeringBloke »
Anyone's car fit over the concrete stops in parking spaces (I don't mean XCs)? My S60 has the same issue as tex69's V70R and the bottom of the front bumper is quite scraped up. I stop back a little now.
Tex69
Year and Model: 2007 V70 R
Has thanked: 5 times
Post by Tex69 »
Oragex,
S60? I'm confused. Also, what is/are PO? Please pardon my ignorance, I'm not particularly car savvy. At least not as much as all of you here.
Where would be a good place to find used coil springs? A pull your own parts place I assume? How will I know if they are any good still?
Thanks
Past: 1993 940 turbo wagon
2007 XC70
Current: 2013 XC60
2007 V70 R
Tex69
Post by Tex69 »
MDK, I understand now. Duh. I'll post a photo tomorrow.
RichHaleParker, I don't know if they did. The specialists, I would assume, as they are usually very thorough. I explained it was a new (used) car, and I needed all safety and inspection issues resolved. But that doesn't mean they did, obviously. I'll have to call and ask.
The guys I use for the basic stuff must have, as I explained the issue I was having and said I had concerns the struts might need to be replaced. But they aren't fluent in Volvo. There are many things with Volvos that are outside their territory.
Note: Can't respond with quotes. When I try, I'm told it contains links to illegal or pirated software. (!!??)
2007 XC70
Current: 2013 XC60
2007 V70 R
EngineeringBloke
To use quotes, click on the double quote icon and you will see
Square bracket, "quote", close square bracket, and then Square bracket, "/quote", close square bracket
Put what you want quoted in the middle between the first close square bracket, and and the second start square bracket.
Example with extra spaces inserted around word "quote":
[ quote ]this is quoted[ /quote ]
this is quoted
Tex69
Post by Tex69 »
EngineeringBloke wrote: 10 Apr 2019, 20:02 To use quotes, click on the double quote icon and you will see
this is quoted
Right, that's what I had been doing. When going to use that function, I was getting that peculiar message. Seems to have stopped now.
2007 XC70
Current: 2013 XC60
2007 V70 R
Has thanked: 1611 times
Been thanked: 4071 times
erikv11 wrote: 10 Apr 2019, 17:53 There is a secret code hidden in the 4C name, hold down the shift key on your keyboard while you type 4C ...
Comfort, sport. Advanced, and poor.
Tex69
Post by Tex69 »
MDK wrote: 10 Apr 2019, 09:15 Hey Tex 69...MDK here. If you could send us a photo of the wagon from the side.. that would help. Some one probably put lowering springs on it using the factory struts. I have an 04 R car and I just stripped out the 4 c suspension... good riddance. I utilized the factory struts and springs from a 07 S60 AWD... I have the code prompt on the dash... but I don't care. MDK
MDK, here is a photo of the front drivers side. I didn't mean to post three, and for the life of me can figure out how to remove the two extra images.
Anyway, let me know if you need more. I have some of both sides from various distances.
Reason: To delete images, go to Attachments tag -> Delete Image
2007 XC70
Current: 2013 XC60
2007 V70 R
Tex69
Post by Tex69 »
MDK wrote: 10 Apr 2019, 15:40 Hey tex... I meant take a photo of the entire wagon... the whole enchilada... from the side. MDK
Oops. Forgot you wrote this. Here are a few more.
2007 XC70
Current: 2013 XC60
2007 V70 R
