Flame trap:erikv11 wrote: 16 Apr 2019, 09:08 ... And non-turbo cars like yours do not have a PTC. You may be thinking of the flame trap orifice specific to NA cars, which can be accessed by removing the air intake from the front grill and/or the air filter box for full access.
P80 Positive Temp Coefficient Nipple "PTC VALVE" To drill, or not to drill
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
tardcart
- Year and Model: 96 850t. 93 940t
- Has thanked: 3 times
- Been thanked: 37 times
Im glad to finely know what PTC stands for, though I've forgotten already. Although I once thought it made sense to enlarge the hole, now I don't, though its reason to be is not clear. I do think that a one way valve should be put on the small vac line from the manifold to allow vac only and no turbo pressure into the PTC area.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Literally not a single issue since I followed your suggestion. I am considering upgrade the pcv hose to a copper pipe when I change out the pcv.erikv11 wrote: 16 Apr 2019, 09:00 I first posted these in ZionXIX's thread viewtopic.php?f=1&t=84698. It's been 18 months now, with no ill effects on my 95 R.
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 53 times
I did this on my non turbo although I used a very tough flexible fuel line. 5/8" I think. My wacky manifold shape requires some flexy bending. I can say that the pcv properly functions. But I still suspect that I have blow-by as my oil smokes every 3000 miles. I just learned to accept that it means that I need to change my oil. HahahahaZionXIX wrote: 16 Apr 2019, 13:30Literally not a single issue since I followed your suggestion. I am considering upgrade the pcv hose to a copper pipe when I change out the pcv.erikv11 wrote: 16 Apr 2019, 09:00 I first posted these in ZionXIX's thread viewtopic.php?f=1&t=84698. It's been 18 months now, with no ill effects on my 95 R.
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
If anyone needs a replacement nipple ...
....I have one from a snorkel replacement.
Peevarino
- Year and Model: 2009 XC70, 97 855R
- Has thanked: 28 times
- Been thanked: 3 times
I thought cats cleaned themselves? Hence all the hairballs. Itโs definitely good to just leave them where they are.Rattnalle wrote: 16 Apr 2019, 07:06 Volvo put it there for a reason. Don't mess with it other than making sure it works by cleaning it.
My two cents.
PS that goes for things like cats and other stuff as well.
09 XC70 3.2
97 855R
97 855R
You are going to fit in here really well.Peevarino wrote: 15 Nov 2019, 06:29I thought cats cleaned themselves? Hence all the hairballs. Itโs definitely good to just leave them where they are.Rattnalle wrote: 16 Apr 2019, 07:06 Volvo put it there for a reason. Don't mess with it other than making sure it works by cleaning it.
My two cents.
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
My two cents.
Don't mess with it still applies though.
While tallying up the votes to kick out the 960s, I read my user manual on my T5 and it reads
PTC cleaning at 60 k miles, and then every 30 k miles thereafter
- 1299 Views
Last post by 98v70xc206
- 1020 Views
Last post by kahl
- 832 Views
Last post by G Martin
- 879 Views
Last post by Sommerfeldt
- 750 Views
Last post by ZionXIX
