07 S60 Immobilizer / Communication Errors / No Start
d3ktrix
Year and Model: 2007 S60
Has thanked: 7 times
Post by d3ktrix »
precopster wrote: 23 Apr 2019, 03:31 Look up number of keys fitted in CEM parameters. Could be that key data is lost. Are you using Vida?
It shows 2 keys fitted.
We have tried both keys and the car behaves the same with both. The batteries in them are good.
I'm using an Autel Maxisys pro.
Thanks
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Because most codes are ECM based and there are now ghost codes such as camshaft sensors I'm going for either a faulty ECM or a dirty ECM edge connector. Has this been cleaned yet?
The latch code for the keys is held in the ECM so that makes sense that the immobiliser display is showing as well as relay codes.
d3ktrix
Post by d3ktrix »
precopster wrote: 23 Apr 2019, 06:21 Because most codes are ECM based and there are now ghost codes such as camshaft sensors I'm going for either a faulty ECM or a dirty ECM edge connector. Has this been cleaned yet?
I have not done anything with the ECM yet. Though I noticed that also.
I'm guessing the edge connector is the main connection on the ECM when it is slotted into the car?
I do not have the special tool to remove the ECM. Though no problem buying it if we need it.
precopster
Yes the edge connector is on the base of the ECM. There are pink sliders in there that can release the modules but I'd rather use the special tool.
Wouldn't hurt to clean the TCM with electrical contact cleaner while you're in there.
d3ktrix
Post by d3ktrix »
Yeah I just found a YouTube video explaining how the pink sliders work without the special tool. I'll pop the plastic shroud off ECM/TCM and see if I want to mess with the sliders lol
Thanks for the info.
precopster
Bosch computer is ECM. The other one is probably marked TEMIC.
d3ktrix
Post by d3ktrix »
Well I think we figured it out.
The connectors on the ECM looked great, but I noticed it looked like water had been flowing down the side of the aluminum ECM cover in the past. So we popped the ECM open and it had corrosion everywhere on the back side of the PCB.
Wonder if ultrasonic cleaning would bring it back to life or if it needs to sent out or if its shot lol
Ill try cleaning it first and go from there I guess, we'll find out if anything burnt out.
Thanks for the help everyone.
And thank you precopster for pointing me towards the ECM =)
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Could be mineral deposits (from the water) creating leakage currents.
Wash the board with Electrical Contact Cleaner.
[youtube][/youtube]
Active
Past
d3ktrix
Post by d3ktrix »
RickHaleParker wrote: 23 Apr 2019, 14:20 Could be mineral deposits (from the water) creating leakage currents.
You might be right, i was thinking it already went the step further and turned to corrosion.
I will def try to electrical contract cleaner right now before taking extreme cleaning measures haha.
Thanks again.
precopster
A used ECM with the same Bosch part number can be cloned to suit the car. You'll need a Windows laptop and a Dice tool. I can fill you in and point you in the right direction with regard to who can do this for you when/if the time comes.
