Glue recommendation for door panels?
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
wrybread wrote: 29 Apr 2019, 11:44 The passenger door panels in my s70 have separated. Any tips on what glue to use to reconnect the two parts (see pics)? I was thinking 3m 90?
And any tips on what to use to reattach the "leather", which is a little separated around the door handle?
Parts of both my 00 S70 SE Base front door cards are separate like those pictured by OP wrybread. Haven't had time and now on hold as the suspension is damaged from a black ice slide. I just put some black Gorilla duct tape on the very bottom edge of the door card and door frame. Surprisingly held up in everyday use without any noise or rattles or it flops open at the bottom when in use :lol:.
C1ph3r
Year and Model: 1999 V70T5
Has thanked: 32 times
Been thanked: 7 times
Post by C1ph3r »
Thanks for the tips. Already ordered some 3M hi strength 90 just before I saw your post. I may pick up some of the gorilla also at the local Lowe’s and try on a different door to compare. Doubt I’ll have the car long enough for a real long term test so who knows. Thanks again.
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
MoVolvos
Post by MoVolvos »
C1ph3r wrote: 25 Aug 2024, 19:18 Thanks for the tips. Already ordered some 3M hi strength 90 just before I saw your post. I may pick up some of the gorilla also at the local Lowe’s and try on a different door to compare. Doubt I’ll have the car long enough for a real long term test so who knows. Thanks again.
From the experience with the Gorilla I think it should hold up for quite sometime as it doesn't get direct sunlight though the car interior can get pretty hot during the summers here in NC.
C1ph3r
Post by C1ph3r »
Thats my concern. And I am also in NC. I looked up some avg interior car temps and compared to what these adhesive can operate at. Couldnt find anything on the Gorilla spray but the construction liquid nails fuze max excides that. I think it will be fine. I have ceramic tinted windows as well so that also cuts down on the temps inside the car.
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 97 times
Been thanked: 42 times
Post by jmartin919 »
This is what I've used over the past year and it's held up so far. Brushed it on, clamped it with shims overnight.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
MoVolvos
Post by MoVolvos »
From the color and texture of the door panels it looks like the original glue was also some kind of Contact Cement. I think they all are about the same unless it's label for some extreme or special application.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
But Volvos glue is a two part pumpkin / tofu based adhesive. Can't get that around here.
1999 V70 GLT
MoVolvos
Post by MoVolvos »
Sveedy wrote: 26 Aug 2024, 15:21 But Volvos glue is a two part pumpkin / tofu based adhesive. Can't get that around here.
Ahead of it's time till it wasn't.
