Need help with strange issue
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
It could be one of the drive shafts. Isn't there a balance weight on the passenger side? If that is missing, it would shudder. I'm not 100 percent sure there is one supposed to be there. Are the driveshaft boots worn?
Since it is FWD you can be safe it is not the angle gear or the rear shaft bearing.
If the motor mounts are completely shot you would get really bad vobration, but that should be felt at idle as well and then while shifting.
1996 855 R,
2010 V70 D5,
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
potiusmori wrote: 15 May 2019, 19:56 Upon further inspection the upper engine mount is basically gone. Dont have much hope of the other mounts being much better but too dark too tell. Can bad mounts really be the cause? Can they cause so much vibration it feels like a bad tranny or a dead cylinder?
This was my first thought. My front mount separated a couple of years back, and together with the right mount, it made quite the horrible feel. Mounts aren't very expensive, luckily, but the right and left ones are PITAs to replace. The front mount, top and lower torque mounts are easy, though.
- S
[Sold] '97 S70 T5
potiusmori
Year and Model: 850R 1997
Has thanked: 5 times
Been thanked: 2 times
Post by potiusmori »
Yea im gonna inspect all mounts in a couple hours after work. I considered the cv acles and possible driveshaft(before seen its fwd) but if any shafts were the culprit then shudder/vibration would stop when car is stopped cause the shafts wouldnt be moving while car is stopped.
Clemens
Post by Clemens »
Oh, I though they stopped when stopping. Then forget what I wrote.
1996 855 R,
2010 V70 D5,
manovlov
Has thanked: 672 times
Been thanked: 163 times
Post by manovlov »
abscate wrote: 15 May 2019, 19:16 Your wife is awesome and you are a lucky man.
:mrgreen:
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 112 times
Been thanked: 17 times
Post by GlennG2759 »
Yes, indeed. Mine did. I replaced it, no more problem. If that doesn't do it check the one under timing belt. Good luck.
potiusmori
Ok so quick update: i was slightly wrong. In park and nuetral there is no shake/shudder. In reverse there is almost none at all. Im talking the barest bit. So shudder/shake only happens in drive. Doesnt matter still if im stopped or coasting at 25 or 65 on highway it all feels same. Checked mounts and 3 of the 4 are shot but past owner replaced lower passenger side recently. So all in all im still were i started just a little more scared of a dead/bout to die tranny. Was told its still a good chance its the mounts so ordered a kit just to rule it out. Transmission fluid looked bad. Not black and didnt really smell burned just very thin and definitely was at the turning point into brown. Gonna drain/fill a few times over next 2 weeks and mounts should be here in a few days
potiusmori
On a side note how difficult will it be to rebuild this tranny. I know everyone is different so just for a reference point i can rebuild a dodge 360 motor in a couple hours mostly by myself. However that being said ive never rebuilt a tranny before lol. And if its too hard anyone selling a manual setup lol
Sommerfeldt
If the transmission shifts okay, doesn’t clunk or hesitate, that’s not likely to be your issue. If 3/4 mounts are bad, and the upper mount was bad as well, that is still top of the likelihood list. Remember that when idling or in park, the engine is just sitting there on the mounts. It’s not under any load and wouldn’t shake or shudder no matter what’s up with the mounts.
- S
[Sold] '97 S70 T5
potiusmori
So im having an issue with ordering the lower right mount. One says chassis# up to 540000 and the other says up to 566xxx. The chassis # is the last 6 of the vin and mine is 767xxx. So which one do i buy?
