Crush washer?
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 157 times
Been thanked: 6 times
Post by Mr. Detail »
Thx XC70Rider. While I am on the topic can anyone tell me where the AT plug is? I will assume the oil drain plug is the one directly straight back and off to the driver's side of the oil filter but I am not sure where the ATF plug is.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I wrote a DIY ATF change for 1998 S70 and 2005 XC90 2.5T.
The AT drain plug requires 24-mm wrench.
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
The large ATF drain plug is on the bottom right side of the AT facing the engine. If you don't have a 24mm wrench then a 15/16" will work. The crush washer is same size for both engine and AT drain plug. The ATF needs to fully warmed up driving via all gears before the drain. You'll drain ~3.5 quarts. Measure what comes out and add in new 3309 ATF via the dipstick.
For questions on which ATF to use or location of dipstick do searching on this forum. It's been discussed numerous times lately
Mr. Detail
Thanks much guys.
Has thanked: 1610 times
Been thanked: 4065 times
Are the P2 models the one that people inadvertently ruin their transmissions removing the wrong fill plug?
Not to make you snap to attention, Mr Detail
(He smugly posts with his array of manual transmission cars)
Mr. Detail
abscate,
Now you are scaring me. When abscate said "bottom ride side of the AT facing the engine", I am not even sure which square metal pan that is. Is he speaking of leaning towards the drivers side if the car?
Post by cn90 »
Mr. Detail wrote: abscate,
Did you search for the DIY I posted?
XC70Rider
Post by XC70Rider »
Mr. Detail wrote: 22 May 2019, 11:30 abscate,
viewtopic.php?f=9&t=89571
