2013A XC90 - 150,000 Miles To-Do List Topic is solved
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Smokepants wrote: 08 Aug 2019, 08:00
Thank you Paul!
I’m going to do the dump, measure, refill with same amount. From what I have read you can do this a few times to cycle the old fluid out. I don’t mind this approach. I don’t have the means to monitor the tranny temp to set the level with vehicle up to temp and running. My scangauge works on my VW for this but can’t find info about using it on the XC90.
The ATF specification for MY 2013A were revised. Make sure you have correct ATF type for 2011. Unless someone says otherwise, a 20-minute of idling will bring you in the range of VIDA recommended 50ºC temp, NOT above 60ºC. The ambient in our garage is close to 70º-72ºF.
Once heated, ATF temp rises quickly, make the drain for LEVEL at 40T a quick task.
Do not forget to shift through the gears with 10sec between each gear after the fill -- engine NOT running. Repeating few times during the ATF warm up has worked for me.
Smokepants
Year and Model: 2011 xc90
Post by Smokepants »
Thanks for the tips. I will have to get it done before the snow flies. Going after the rear end, Haldex, and front angle gear fluid first.
xHeart
Post by xHeart »
Vac pump serviced, installed and working. Now moved on to work on water pump, belt, pulley and tensioner replacement. Belt tensioner cocked, belt loosened, ps fluid line removed. Fun engine to work on relative to our V70XC.
xHeart
Post by xHeart »
With vac pump and tensioner removed, the ps pump takes somersault and steers out with relative ease -- imagine reversing your car from the driveway to the street, and then twisting forward toward the compressor for a lift off.
Belt shows cracks all over. Now preparing to replace and install.
xHeart
Post by xHeart »
Cleared the space to install new water pump and coupling.
Now that I have done it. Rehearsing PS pump install, I say, it is possible to remove and install water pump without vacating PS pump -- just push it back as far in to the bulkhead.
Now taking a break, waiting for the new rebuild BOSCH/ZF PS pump to arrive, meanwhile few pix.
xHeart
Post by xHeart »
Tools from HFT for woking with two 25 torx screws at the PS pump pulley to coupler. The screw can be reached from behind the pressure hose connection -- a straight shot, pulley is rotated so screw is at 12 0'clock. It is better with black knob off the jig.
This is job takes good old dexterity working with 10mm wrenches. No space for torque tool, so go by experience.
Has thanked: 1611 times
Been thanked: 4072 times
Hey, that’s a puppy diaper!
Woof woof woof
xHeart
Post by xHeart »
abscate wrote: 08 Sep 2019, 04:30 Hey, that’s a puppy diaper!
Woof woof woof
It once was. She is now a fully grown loving family dog.
It may just be a placebo, but the engine feels quieter. The new tensioner, belt, pulley, water pump, coupler, and rebuild BOSCH/ZF ps pump are working together with no issuse. The coolant level is now stable. Crowfoot NOT flare wrench is best for the pressure hose connection at ps pump.
Next item for this service interval is Haldex. Control unit repair kit pn 31259351, and filter pn 31325173 in 60 days.
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 120 times
Been thanked: 189 times
Post by pgill »
Excellent summary!!!!
And very nice pictures.
As for the Crow Foot vs Flare nut comment
I think I used --> SK Hand Tool 42316 6 Point 3/8-Inch Drive Full Polish Crowfoot Flare Nut Wrench, 16mm
Amazon has some amazing deals on parts that are sitting in inventory for a long time.
List price is $30.35 (regular price at SK web site) and I paid $7.56
I could be wrong it may have been 17 mm and not 16 mm (I can't remember for sure)
I do recommend changing the O-ring
For me I use the Land Rover part because I was already buying some Land Rover parts
LR009387 O-ring for power steering pump (Volvo Part# 31202809)
I apologize for not recommending the O-ring replacement sooner.
Take care
Paul
pgill
Post by pgill »
Pictures of the O-ring
