EZ oil drain valve anyone?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Has thanked: 1497 times
Been thanked: 3809 times
Re: EZ oil drain valve anyone?
A magnetic pickup works for retrieving thatbolt, ofc just wear nitrile gloves and don’t drop it in.
My magnet is named Henry. He’s attractive, or at least the poles say he is.
IslandV70
Year and Model: 2005 V70 2.4
Has thanked: 2 times
Been thanked: 3 times
Post by IslandV70 »
MoVolvos wrote: 20 Aug 2019, 19:02
IslandV70 wrote: 20 Aug 2019, 12:35 I just use my vacuum oil sucker from the top. I never liked those valves.
You mean something like this? Do you warm your engine? I'm hoping to soon use mine for the 1st time.
https://www.amazon.com/gp/product/B00LC ... svolvo3-20
I use this one - https://www.westmarine.com/buy/west-mar ... cordNum=11
It works well if the oil is hot, so you need to drive the car around some.
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 64 times
Been thanked: 69 times
Post by Georgeandkira »
My 2¢:
With friends in auto tech school (long time ago) the word was "They leak-stay away" period.
I decided to install a Fumoto onto a neighbor's 2010 Honda because the quick lube dolts stripped his pan threads.
Fortunately there was enough thread-grab left but I still added a bead of Permatex Ultra Black if only for the gluiness.
I had recently read nothing but glowing reviews and Fumoto's HQ is on 34th St. There's nothing like going to a sparse office filled with bins and outgoing packages. The dirty windows and scorched coffee pot add so much ambiance.
The drain hole is in a shielded location with the 4 cyl. engine. It saves time and is less splashy.
I give it an "A".
I'd gladly install one on my car but it would be vulnerable, so NO WAY.
amblerman
Year and Model: 1999 s70
Been thanked: 70 times
Post by amblerman »
I had a fumoto valvue on my 1997 VW jetta TDI. Had it on there for years. No problems at all.
Upside: oil drains out more slowly and gently so that you aren't dealing with a sometimes chaotic stream of hot oil that likes to splash around.
Downsides: oil drains more slowly.
I am currently running magnetic drain plugs on all my cars but if I ever decide to go back to a valve, I'd probably get a fumoto again.
btw some people worry about the valve lever accidentally opening. I don't see this really being an issue. However, they make a clip to prevent that. Instead, I just put a zip tie in the groove to prevent the lever from getting out of it's locked position.
The oil change procedure then became: clip zip tie with wire cutters, rotate valve. Simple.
-A
P2s could stick a hose on that and just pull it out into the drain pan, then flip the valve open.
Wait, If i go to a parking garage, I could park one level above, then drain the used oil right into my 99 with a long hose.
reverend
Year and Model: 2006 V70 2.5t
Post by reverend »
I have this one in my car and it's worked well for many years. It's the Fumoto valve. Sorry for the potato picture.
IslandV70
Post by IslandV70 »
I used to fly an airplane with one of those valves and we took it off after another airplane had the landing gear come up, whack the valve, and drain all the oil out in flight.
I hope they dead sticked the landing...
:-O
