How can I replace an 850 lower control arm bushing?
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
erikv11 wrote: 12 Sep 2019, 09:33
abscate wrote: 11 Sep 2019, 14:07 ... Just missed the start of the FCP lifetime warranty with that one.
I don't think that has a start date. If you bought it there and have documentation, they will honor it.
Unless FCP says otherwise, the Lifetime Warranty is effective only after the "manufacturer's warranty" has expired.
Has thanked: 1610 times
Been thanked: 4065 times
I think your invoice has to have the FCP LIFETIME WARRANTY line on it to qualify.
5 years 75k on a FAG front wheel bearing isn’t too good is it?
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
abscate wrote: 12 Sep 2019, 17:07 I think your invoice has to have the FCP LIFETIME WARRANTY line on it to qualify.
75k seems abysmal TBH.
I've just been credited for warranty returns on some 2014 purchases, trunk struts. It does say warranty at the bottom of my electronic order invoice, but it didn't say that when I bought them.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
abscate wrote: 12 Sep 2019, 17:07 ...5 years 75k on a FAG front wheel bearing isn’t too good is it?
Mileage is about right for front Fag wheel bearings.
75k miles is around 120k km.
Rear ones seems that they outlast the car.
Never seen those ones failed.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
I was set to go on the LCA bushing replacement, but when I got up close discovered it wasn't as bad as I thought—it was last spring when I had it in for alignment. Just for the lark of it, I decided to unbalance the front tire pressures a bit to see if that would reduce the pull. It does!
Not completely, but enough so I'm no longer concerned about it. If I notice uneven tire wear, I'll reconsider on the bushing.
