Kudos to spouse for being aware of changes in the operation. The alternative is the kind who don’t notice the little genie oil can light is lit up on the freeway and drive on, for a short distance.
How many miles are on this beast?
I solved an intermittent rough idle finding one split vacuum hose in the purge circuit. If those are still original, spending an hour to replace everything makes sense
Coils and plugs should all come out, if they have 150k or more on the coils, I would put 5 new ones in. Sell the other 5 for $50 with an asterisk that one is bad. I just had a coil on the 1999 that failed at cold start then cleared up, then would fail ten minutes later
Perplexing Misfire. Only when started warm
- Been thanked: 4068 times
- 2140 Views
Last post by optowalt
- 3540 Views
Last post by 93ForMe
- 827 Views
Last post by oragex
- 1385 Views
Last post by cuhfs
- 1930 Views
Last post by jakeempero
