Need info on 850 and P2 driver seats
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
misha wrote: 20 Jan 2020, 15:02
CIK7 wrote: 20 Jan 2020, 12:11 ...Both of my 98 have the SIPS instead of the electronic ones.
850s from late '95 & s,v70 ...both have SIPS(Side Impact Protection System)airbags.....difference is that 850 have them mechanically triggered and s,v70 have them electronically triggered...BUT designations are the same SIPS airbag.
850s from '91-'95 have only SIPS without airbags.
Both my SIPS are not connected via electronic/wire. They only have the cylinder with the clip and tube. I'm pretty positive mine are mechanical.
It was 99 (after Ford took over) that the electric SIPS were implemented.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Are you sure that seats are original and not replaced with late '95-'97 850 front seats?
They are interchangeable and almost look identically.
EU cars (s,v70)have electronically sips airbags...from introduction of S,V70 models in '97.
I'll show you a wiring diagram for SRS system where you can see yourself that s,v70 cars have electronically triggered SIPS airbags(linked with crash sensor)from '97-'00(P80 cars) and 850s from late '95 -'97 SIPS airbags are not linked with crash sensor.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1611 times
Been thanked: 4072 times
It’s both model and market dependent with EU getting the good stuff a year or two in advance of the rest of the US
Has thanked: 2209 times
Been thanked: 1852 times
The heated seat portion is different on -98 and 99- cars. The wiring is different for the seat underneath, but I was able to swap the part over I needed. If I recall also the heated seat on -98 have the wires to the seat element going up through a hollow in the middle of the seat base cushion, and on the 99- the wire goes to the back of the seat base. I would suggest that they also used different seat heater mats as well because of this.
If the -98 heaters do not work it is A) because the heater element has failed, or B) the wires have broken under the seat. The design allows the wires to the seat element to move in the hollow cylinder to the connector in the seat base cushion every time the seat is moved and eventually they will break either the connector or the wire. IT can be repaired but is likely to fail again unless you find a way to take the strain off the connector by say stuffing the hollow cylinder in the foam with something to protect the wires.
bill d cat
Year and Model: 1998 V70 T5M
Been thanked: 7 times
Post by bill d cat »
Based on many times my driver's seat has been apart over the years, my '98 V70 has 850-style mechanical detonators (and the red safety gizmo) that look just like the ones in this thread:
viewtopic.php?t=91141
'98 V70 T5 232K mi., 5-speed manual, 3rd evaporator, 3rd windshield, 7th remote shell, heated velour seats, factory HD suspension, IPD stabilizer bar, Volvo strut tower brace and skidplate, XC grill, E-Codes, V-1, JB Weld, Duck Tape, zip-ties, Mobil-1 since new. Goal: MADE IT to the MOON! (was 221,524 miles at perigee November 14, 2016.)
These features came in different models, labels, and model years across world markets.
CIK7
Post by CIK7 »
misha wrote: 21 Jan 2020, 07:00 Are you sure that seats are original and not replaced with late '95-'97 850 front seats?
The 5 v70s I've seen, they all have identical seats.
