Your 1998 does not need dash removal. Take out the glovebox and then remove the plastic panel under the glovebox. Check the vent damper closest to you, the plastic may be broken.
The reset procedures are the same as the 850, quite involved, and all of the vents must work before initiating reset. You will need to make a code reader.
Electronic Climate Control Reset Procedures
I have a similar situation. I started the ECC damper motors recalibration through VIDA on 2 different units and in both it didn't finish the process, making the unit keep flashing the ac green light and disabling the air distribution and temp control on both sides.
Before starting calibration the air distribution worked perfectly and also the left temp regulation, but the right side was blowing cool air instead of warm/hot.
There were no ECC dtc or faults so my guess was to just re calibrate dumper motors.
There should be a way to hard reset the ecc unit to get it back to defaults and not keep starting the recalibration process (and getting stuck on it) everytime you run the car.
Anyone would assist with this?
- 11 Replies
- 6804 Views
Last post by maxi948
- 3489 Views
Last post by caliwagon
- 700 Views
Last post by Top Notch
- 1454 Views
Last post by jreed
- 1717 Views
Last post by mydamnvolvo
