What style of radiator hose clamp do you prefer?
Has thanked: 1610 times
Been thanked: 4068 times
Four things
The open notches cut the rubber into pieces
The bottom of the bolt portion has two sharp edges on the cheap ones which also slice the rubber
The tolerances on the cheap ones suck
The metal quality in the cheap ones is silver cheese and looks like this - yes - these were 'stainless'
Screen Shot 2020-03-11 at 4.02.38 PM.png (732.9 KiB) Viewed 1357 times
abscate wrote: 11 Mar 2020, 03:43 We should get a group buy together for all of with multiple Volvo’s.
You can get ABA clamps in durazinc here , from Belmetric
About $2 a piece and they drop to 1.50 USD in qty 10 or more
https://www.belmetric.com/aba-blue-hose ... -6922.html
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
I like these for radiator clamps on silicone hoses... Note: This is not the correct size...
https://www.amazon.com/Breeze-Constant- ... 166&sr=8-3
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Neil is correct you want the European clamps for those reasons on critical hoses and yes my dealer has some of the sizes but for others they sell the generic crap.
I found McMaster Carr a good source, they are German made
https://www.mcmaster.com/screw-clamps
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
That brownish stain is called a corona stain.. No that wasn't a lame attempt at a joke.
See here:
http://www.ngk-sparkplugs.jp/english/te ... index.html
Good description here from the folks at NGK.
amblerman
Post by amblerman »
abscate wrote: 11 Mar 2020, 14:01 Four things
Those are all excellent points. I have been a little spoiled on some of these issue as I inherited a huge number of hose clamps from my dad. He was a sailor and had a lot of stainless clamps rated for marine use. ie: real stainless.
Some/most still suffer from the hose cutting issue but they do not rust.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Unfortunately, some grades of stainless are not very corrosion proof. Grades 304 and 316 has good corrosion protection. Other grades made have less protection, but can still be called stainless.
befarrer
Year and Model: 1998 V70 AWD
Has thanked: 1 time
Been thanked: 24 times
Post by befarrer »
I prefer the spring clamps, they allow for heat expansion and contraction. Give the right pressure on the hose too. Just a pain to install and remove.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
volvolugnut wrote: 13 Mar 2020, 10:09 Unfortunately, some grades of stainless are not very corrosion proof. Grades 304 and 316 has good corrosion protection. Other grades made have less protection, but can still be called stainless.
While I don't doubt what you say, this is weird. What's the point of stainless that isn't stainless?
1996 855 R,
2010 V70 D5,
Stainless steel is a generic description. The actual grade tells the true characteristics of the material. The various grades can be magnetic/ nonmagnetic, corrosion resistant or not, weldable, easily machined, very strong or weak, etc. As in most industrial stuff, you need to know the details.
A comment on the constant torque type hose clamps: in a previous job, we only used this type on radiator and turbo hoses of industrial diesels. All others would blow off under pressure. We also found we had to restrain the hoses so they could not move outward from the hose nipple and slide off. When the turbo hose blew off the engine immediately stopped. When radiator hoses came off, you wanted to be aware and immediately shut down the engine.
