'99 V70 FWD, Auto, Base, 235K miles -- Toasted PNP? Topic is solved
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Strange.
Usually...when it will not crank in "P" because of dirty contacts in p'n'p switch....it cranks in "N" without problems.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Which is suggestive that PNP switch is probably not the problem.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 1610 times
Been thanked: 4071 times
E Showell wrote: 27 Mar 2020, 07:48 Which is suggestive that PNP switch is probably not the problem.
I would read that as still a possibility , and the remote starter terminal would basically nail it. If it won’t crank on that terminal, but will if you apply voltage to the spade terminal on the starter, it’s the PNP
E Showell
Post by E Showell »
I'm still fuzzy on the remote starter terminal and associated procedure.
'95 855 auto (sold)
Put it in park and then touch a wire from the terminal to the battery B+
This bypasses the ignition switch and the starter relay
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
E Showell wrote: 27 Mar 2020, 09:26 I'm still fuzzy on the remote starter terminal and associated procedure.
17/1 = Remote starter terminal.
2/35 = Starter relay.
3/71 = PNP.
6/25 = Starter motor.
Active
Past
Can a Vida expertises Remind me what market MSA is?
Those diagrams are horrible when they do that.
E Showell
Post by E Showell »
Sorry guys, I appreciate the numbers and diagrams, but they are incomprehensible to me. Now, if the technique could be gleaned from Keats, Milton, Byron I'd be Ok.
'95 855 auto (sold)
I bumped the remote starter terminal thread with pictures.
Make sure the car is in park
Key to position 2, on, nomcranking.
Touch a piece of wire from the B+ terminal inboard, to the connector In the white housing in the picture.
This should make the car crank and start
E Showell
Post by E Showell »
Thanks Steve. Car fired right up with a jumper wire. Diagnosis seems to be original ignition switch has given up the ghost at 235 K miles.
'95 855 auto (sold)
