A thousand 4T65 rebuilds/repairs observed ... why did you invest that much time in observation?lasseamager wrote: 16 May 2020, 01:46 That dosent mean i havent seen any else than my own - i just DONE my own 2
Transmission issues
- RickHaleParker
- Been thanked: 979 times
Active
Past
Past
lasseamager
- Year and Model: volvo 2002 s80 t6
Because i have absolutely nothing else to doRickHaleParker wrote: 16 May 2020, 02:02A thousand 4T65 rebuilds/repairs observed ... why did you invest that much time in observation?lasseamager wrote: 16 May 2020, 01:46 That dosent mean i havent seen any else than my own - i just DONE my own 2
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
I guess 2 is easier to remember but is that 1000 or 1002 times that you've seen it done?lasseamager wrote: 16 May 2020, 01:46That dosent mean i havent seen any else than my own - i just DONE my own 2MoVolvos wrote: 16 May 2020, 00:58You said you rebuilt 2 of themlasseamager wrote: 15 May 2020, 11:28 i have seen it a thousand times . the band and clutches wear out.
"i have rebuild 2 of my own ( chevrolet trans sports )"
viewtopic.php?p=542602
- MoVolvos
Since we both have a head we both don't have a problem with rain down our necks unless you choose to let it pour on you. As for the head it's what's inside that counts.lasseamager wrote: 16 May 2020, 13:05 What is your problem? Do you only have a head so that its not raining right down your neck ?
In two post you've used "stupid not too" and "seen it a thousand times". People are here to learn so we are less stupid but we prefer to dialog with people a little smarter than us so we can learn rather than someone who is less stupid like yourself. That's the difference between having a head and something inside of it.
Unfortunately, I don't like umbrellas but I am not less stupid and a little smarter because I will find something to cover my head so the rain does not run down my neck. I hope I answered your question.
NorCalBoy
- Year and Model: 2002 s80 t6
- Has thanked: 3 times
This is disturbing to read. I really need help figuring out what i should do with my car and logged on for honest advice and ideas on what i can do to fix it and u guys are on here being rude. go someplace else with that please..
So i have a 2002 volvo s80 turbo that is having tranny issues. It only drives in manual 3rd gear. check engine light is on so i cant smog it. code reader is showing these codes. p0700, p0751, p0756 im trying to figure out what i should do?
- SuperHerman
- Been thanked: 207 times
I posted my thoughts early on. The 4T65E has design issues. What you describe is consistent with a failed transmission related to the design issues. I think you need a rebuild. Clutch/hub shaft has or is failing is a possibility. Second gear clutch pack is beyond service limit is another possibility (or an additional problem). The other possibility, which is what RickHaleParker cured is failed/failing accumulator valves.
Check out this site -https://www.tripleedgeperformance.com/V ... -XC90.html
Navigate around and you will find additional non-Volvo 4T65E issues.
- MoVolvos
Since you are new to the forum the people here have tried to provide the least expensive and time consuming methods to check a problem which is inherent with this transmission. You'll notice lasseamager is new and was condescending and recommending a tear down besides additional work because he was smarter and have seen it a thousand times. Most people come to learn and not pretend to have the last word.NorCalBoy wrote: 16 May 2020, 19:16 This is disturbing to read. I really need help figuring out what i should do with my car and logged on for honest advice and ideas on what i can do to fix it and u guys are on here being rude. go someplace else with that please..
It rarely happens that people are rude on this Forum but I and perhaps some others here don't appreciate that. Most importantly did not want you to spend a bunch of money, time and discover it was a minor issue. (EDIT $150) plus in parts and your time vs transmission rebuild.
Summary: If you've DIY for sometime, following the videos you might be able to quickly find out if you can take care of the problem without a tear down and get the car Smog. Lived in CA from 71 to 05 so know the head aches of getting a smog done in CA. I suggest you carefully read the entire post and follow the links while avoiding the disturbing parts.
Filter Change
Flush
Shift Kit
- RickHaleParker
Day after day seven days a week for 8 - 10 years. That what it takes to go through a 1000 transmissions. Life must be dull for you.
Active
Past
Past
- RickHaleParker
Pull the connector on the transmission and clean it. Clear the codes see if they come back. Do the same with the TCM.NorCalBoy wrote: 16 May 2020, 19:16 So i have a 2002 volvo s80 turbo that is having tranny issues. It only drives in manual 3rd gear. check engine light is on so i cant smog it. code reader is showing these codes. p0700, p0751, p0756 im trying to figure out what i should do?
Check for shorts and opens in the wiring harness. I doubt both solenoid went at the same time and they do share a common ground. If the high side of the two solenoids that would create an ambiguously that would prevent either from operating.
Active
Past
Past
- 11 Replies
- 2576 Views
Last post by dimataeus
- 11 Replies
- 6036 Views
Last post by oragex
- 1900 Views
Last post by leapdragon
- 909 Views
Last post by precopster
- 1116 Views
Last post by draser
