V70 2.4T (P2) ECM-262A (P2097) -upper O2 sensor? -NOPE! Vacuum, Evap & Intake leaks! Topic is solved
Has thanked: 1611 times
Been thanked: 4072 times
Mornin’ Jon boy
5/16 is an almost perfect fit for 8mm, so if it’s tight enough to split I would go with 9 or 10mm. You could clamp 10mm with zip ties if it’s loose. The turbo valve vacuum lines see pressure so should be clamped.
Good night , jonboy
Elizabeth
Jonboy74
Year and Model: V70 2.4T, 2002
Has thanked: 119 times
Been thanked: 15 times
Post by Jonboy74 »
So, for anyone who has read this far.....
Here was another portion of the solution....that I should have done the first go round. If you're going to the trouble of replacing the turbo hoses, just do yourself a huge favor and buy the Evap hose assembly and replace that as well...trust me in this - don't try to do a DIY fix it on the assembly. And if your TCV hasn't ever been replaced....its probably time.
You can thank me, and the rest of the contributors, for this later. :-)
P2097 Woes... AGAIN.... V70 2.4T (P2)
Have fun!
Jonboy
Those short term fuel trims are great , nailed in low.
Have a check of your fuel pressure to see if it is in spec. If you are on your original fuel pump, it’s getting long in the tooth.
Jonboy74
Post by Jonboy74 »
And for anyone who has read this far....
There was one more piece to the puzzle - a leak in the air intake between the MAF Sensor and the Turbo intake. Have a look at this thread:
P2097...driving me bonkers... yes, AGAIN (P2 - 2002 V70 2.4T)
Jonboy
Jonboy74
Post by Jonboy74 »
For anyone who has gotten this far, to close the loop, the other lines that were larger in diameter and looked like fuel lines, those are actually an assembly, here:
Volvo Evap Hose - Genuine Volvo 30757307
If you want all of the nitty gritty details, go here:
Jonboy
