'04 XC Engine Misfiring-Further Updated (Moisture ruled out - possible defective coils, bad MAF) Topic is solved
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Yep, but by me, the black bears could decide they want it.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- E Showell
So, intermittent Misfire back today. Spoke with mechanic who suspects two of the new coils could be bad. I'll swap out with some of the old coils and check it out. Failing MAF is also a possibility. Watch this space. I'll keep it updated.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
So VIDA had given me misfire and another code ECM 130A - induction leak.
If I have a bad MAF will it give a MAF-specific code, or could the cylinder misfire codes be the only codes I'll ever see?
Here's my issue. Since the misfire is intermittent, if I switch in a couple different coils and it goes away, it could simply be due to the intermittent nature of the fault, not the fact that I put new coils in.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
Switched coil #5 with #1, #4 with #2, no misfires, so either the issue is intermittent, or MAF could be suspect.
'95 855 auto (sold)
'95 855 auto (sold)
If we do Hazleton I’ll try find my spare good P2 coils.
With two cylinders misfiring, don’t read too much into that MAF CODE.
IF the car is missing on two, air flow will be crappy and spurious codes will abound.
I don’t think MAF will give misfire like that, coils much more likely. Don’t rule out plugs either. Remember my famous “ one week after out of box “ failure
93SCMax
- Year and Model: 2001 V70 T5 mt
- Has thanked: 36 times
- Been thanked: 45 times
Just a couple comments to help you (and us) troubleshoot.
1) My original advice about the MAF was only geared toward the "limp home mode", not an intermittent misfire. I'd move on from the MAF at this time.
2) Your 2nd to the last last post mentioned a misfire code...cylinder specific or generic (ie. ECM 3503)? Please list codes after each reappearing failure.
3) If not a specific cylinder, you may have fixed a grounding issue when reinstalling the coils switching cylinders.
4) Did you/your mechanic install Volvo spark plugs? If not, what did you install? As abscate suggested earlier, check the plugs, regap and reinstall, or move to a different plug. I'm a firm believer in only using Volvo plugs if you want long, failure free performance. Cost more but no hassles later.
- E Showell
Volvo plugs only always.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
Latest update -ECM 91B7 -Throttle Valve, faulty signal. Looks like could be time for a new throttle body, no?
On starting today, rough, lumpy idle with rpm fluctuations, felt like cylinder misses, but no codes for cylinder misfires.
Bad throttle body looks like the issue.
'95 855 auto (sold)
'95 855 auto (sold)
I would still try some coil swaps. Remember that misfire codes have to satisfy software conditions, they aren’t immediate
- 3118 Views
Last post by itsmekirby
- 5974 Views
Last post by chrism
- 2239 Views
Last post by MoVolvos
- 354 Views
Last post by JaredR
- 26 Replies
- 6416 Views
Last post by ChadLee
