98 XC: removing a bent/broken connecting rod Topic is solved
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
yanga001 wrote: 10 Nov 2020, 07:21 someone needs to make some laparoscopic volvo surgery techniques. Make a small incision in the cylinder head, grab the broken connecting rod, tig weld suture the hole...
:lol: rolling on the floor! Too funny!
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
CIK7
Post by CIK7 »
I chose yanga001 as having the best solution: making an incision ahahahahahahhahhahhahahahaha
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
I know of very few engines that have the crankcase size to remove piston from the bottom. The ones that allowed it were old engines with 6 cylinders and 4 main bearings or 4 cylinder with 3 mains. Old tractor engines and some welders, etc. even those required the crankshaft be removed first. Look at the cylinder spacing in the photos showing the block and then look at bottom end photos. The main bearings are a lot wider than the cylinder to cylinder spacing so the bearing support part of block is far too wide for a piston to come out the bottom. On V6 and V8 where there are fewer mains, the main bearing supports are just below the cylinders so not enough room to bring piston out of bore and then move it over to bring out bottom.
Has thanked: 1610 times
Been thanked: 4071 times
I think it has to come out the top
Crank removal would be an engine out job.
Antler-man...I’ve got a 1998 motor out I can pull a piston and rod. You might have to spec and source rings to match but that would save a big tear down.
Has thanked: 2207 times
Been thanked: 1852 times
Biggest issue is most engine need the piston rings to be dropped in from the top with a piston ring compressor. Putting in from the bottom is likely to break the edges of the rings.
