2001 V70 Anyone know where this sunroof piece goes?
- prwood
- Year and Model: 2001 V70 2.4T
- Has thanked: 9 times
- Been thanked: 22 times
So here's another question... what IS the purpose of these metal strips at the front and back of the sunroof glass?
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
Why would you want to use glue again? thats why they came off in the first place. The 3M automotive grade tape used with the 3M primer. TIP heat up the tape before applying.
I think its to keep the help the seal when closed.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- prwood
Would this be the tape?darrylrobert wrote: 19 Jan 2021, 04:35 Why would you want to use glue again? thats why they came off in the first place. The 3M automotive grade tape used with the 3M primer. TIP heat up the tape before applying.
https://shop.advanceautoparts.com/p/3m- ... /6012221-P
And the primer?
https://www.amazon.com/3M-Primer-0-2oz- ... 00HVEW9ZW/
The tape seems to be readily available locally, but the primer not so much.
Cars I've owned:
- prwood
Update: I used JB Weld to reattach the metal strip. Clamped it down in multiple places overnight and it seems to be attached very securely now. I reattached the glass using the new screws and washers and they are very securely tightened. My torque wrench doesn't even go down to 5 Nm, so I just tightened it to the point where the screw and washer were holding in place.
One thing I am unsure of is the proper height for the sunroof. The openings for the screws on the sunroof glass seem to allow for a few mm of movement up, down, left, and right. My gut instinct was to try and place the screws dead center. This resulted in the sunroof glass resting just slightly below flush with the roof surface. Not sure if this is correct or if I should try lifting it up a bit so it's more flush.
Cars I've owned:
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
See the last page for recommended height adjustments.prwood wrote: 24 Jan 2021, 19:35 Update: I used JB Weld to reattach the metal strip. Clamped it down in multiple places overnight and it seems to be attached very securely now. I reattached the glass using the new screws and washers and they are very securely tightened. My torque wrench doesn't even go down to 5 Nm, so I just tightened it to the point where the screw and washer were holding in place.
https://automotivetechinfo.com/wp-conte ... Repair.pdf
- 1086 Views
Last post by Richard99
- 1405 Views
Last post by vjaneczko
- 1878 Views
Last post by bmdubya1198
- 1203 Views
Last post by RickHaleParker
- 1409 Views
