Off topic - extreme temperatures for central Canada
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
abscate wrote: 07 Feb 2021, 08:42 At -40 Fahrenheit and Celsius converge, admit indeed does not matter.
Indeed, the two scales intersect at -40.
-40 degree Celsius = -40 degree Fahrenheit
Active
Past
Has thanked: 1610 times
Been thanked: 4065 times
-40C = -40F = - F* Cold
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
Blacklab467 wrote: 07 Feb 2021, 10:50 This weather is certainly hard on cars, even well maintained ones. If you can, plug in your block heater ( if you have one) or park inside a heated garage. My car sits outside because the truck and wife's car live in the garage. The Volvo will start without being plugged in as low as -38 which is great but it makes me cringe thinking about the wear that is happening for the first few minutes!
One thing I install on every vehicle we own is an oil pan heater. I learned it from the Eskimos in AK :)
Spinning that crankshaft through honey takes a lot out of the battery.
I once measured the dipstick temp when we had a cold spell. It had been -30F for ~2 weeks. I left the hood ajar the night before (because replacing hood cables isn’t fun & an almost certainty if you try it when it’s that cold!), had the heater on a timer for ~2 hours prior to startup. Dipstick temp measured with a IR thermometer was a balmy 63* :D
The car was parked outside as well & definitely good & cold soaked!
https://katsblockheater.com/block-heate ... heater-150
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
erikv11 wrote: 07 Feb 2021, 13:00 Forecast here for the next week is cold but not that bad, the range is approximately -5 F to +5 F for the highs. Currently 4˚and sunny here.
It is ±10 in our area, hence a dog walk is limited to as soon as she is done.
FWIW, the annual oil and filter change has been Nov/Dec for many years now -- Pennzoil EURO 5w40. Also, it is plugged to a trickle charger overnight in our driveway when temps are below freezing, using:
