@xheart, the car is still at the mechanic (till tomorrow). Most likely I will tell them not to attempt fixing the blower motor.
I agree with you, @erikv11. There's no way that's where the noise is coming from. Maybe after the control arm bushings are fixed the noise will go away? I'll do as you suggest, and remove the blower motor fuse once I get the car back.
Thanks both
Unrecognized suspension/break squeak on XC70 Topic is solved
fontoledo
- Year and Model: 1993 240 Sedan
- Has thanked: 2 times
Hey friends, coming back to this, as it was solved.
My mechanic backed down with the hole blower motor lead. Instead, we ended up doing the following:
Thanks all.
- Replaced front and rear lower control arm and control arm bushings
Replaced Front left inner and outer Tie Rod and Tie Rod Boot
Thanks all.
- 11 Replies
- 11070 Views
Last post by casbah99
- 578 Views
Last post by PIZZABYSTORMED
- 542 Views
Last post by matthew1
- 1028 Views
Last post by SuperHerman
- 14 Replies
- 2819 Views
