VIDA 2014D_Repack install on Windows 10, any version.
jpierre
Year and Model: XC70 2011
Post by jpierre »
Thank you Rick for your reply.
I found the language packs in my previous HD (the previous PC had VIDA 2013 installed).
I applied the procedure you mentioned above. I surely did something wrong... after clicking on FR shortcut, when I launch VIDA, enters 4 and logins, it tells me that the language is not the one used during install. I'm stuck at this point now...
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
jpierre wrote: 27 Nov 2021, 05:56 I applied the procedure you mentioned above. I surely did something wrong... after clicking on FR shortcut, when I launch VIDA, enters 4 and logins, it tells me that the language is not the one used during install. I'm stuck at this point now...
I am thinking the language pack need to be added to the install DVD. Where and how I don't know.
Active
Past
GearBoy454
Year and Model: 2010 Volvo S40 T5 R
Has thanked: 1 time
Post by GearBoy454 »
RickHaleParker wrote: 26 Nov 2021, 11:19
GearBoy454 wrote: 25 Nov 2021, 06:11 "Windows cannot find '%VIDA_HOME%patch\filldb.cmd'. Make sure you typed the name correctly, and then try again."
The patch is a self executing WinRAR archive. %VIDA_HOME%patch\filldb.cmd'. referrers to a path within the archive. For some reason your system is having trouble with the archive. Bad sectors due to download errors can cause this. Delete the patch and try download it again.
Thanks for the suggestion RickHaleParker. Unfortunately I am still not able to run the patch successfully. Really at a loss at this point and not sure what to do.
GearBoy454
Has thanked: 1 time
OK, So I went out and purchased a cheap windows machine (I was previously using my wife's) and did a clean install of Windows 10 Pro. I was able to run the scripts and patch, but now I am getting the following message:
"VIDA cannot start as port 80 in already in use"
Unfortunately, it is in use by a system process and cannot be stopped. Ripping out my hair at this point, which is talent considering I m already bald haha. Please help, I am not a Windows guy.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Try this:
Click the start menu
Type in Services
Sort by Name
Scroll down to World Wide Web Publishing Service (W3SVC) and disable it
-- found here https://stackoverflow.com/questions/318 ... es-port-80
Also -> Amazon link
GearBoy454
Has thanked: 1 time
Thank you Matthew1 that did the trick, VIDA is up and running! I just want to give a huge THANK YOU to RickHaleParker as well for making this information available!!
RickHaleParker
UX3 upgrades the VIDA interface so that it work better with today's higher restitution screens.
1. Get VIDA up and running
2. Down load the Zip file below.
3. Unpack the UX3 Zip file.
4. Run the UX3 executable to install.
5. Restart Windows.
6. Wait for VIDA monitor to turn green.
7. Start VIDA.
8. Done
VIDA 2014D UX3.zip
(984.7 KiB) Downloaded 983 times
Active
Past
iowasand
Year and Model: 05 XC90
Post by iowasand »
Hello everyone,
Looking to get VIDA. The iso on the first post in this thread is greyed out for me, is there another way to download it?
Edit: I figured it out. Had to YouTube how to use qBittorrent. Thanks for your post!
mihai78
Year and Model: v40
Has thanked: 1 time
Post by mihai78 »
Is working. I had same issue but I deleted and put back the link and is working now. :lol:
Regards
JanDzbanowski
Year and Model: 2004 V70
Post by JanDzbanowski »
Hi
Installed vida according to guide, works fine (gets all car information) until i go to diagnostics page and want to check fault codes. When i click on fault trace or any other tab in diagnostics exept information tab i get this error:
with this descritption: https://pastebin.pl/view/be2cdad6
So i googled that error and in most cases people were missing NET Framework 3.5, but i have it enabled as in the 1 point of the guide:
Im using windows 10 laptop with J2534 MongoosePRO JLR interface (i know i should have gotten dice interface but they seem crazy expensive or not avaible here at the moment - also can't find chinese versions on aliexpress anymore).
I've tried:
- disabling an reenabling net framework 3.5 (so it installs once again)
- using vida with enabled/disabled framework 4.8
- using ie11 as well as ie tab plugin in edge
- lowering all security in ie11 options
- unistalling vida and sql server and installing it once again
- installing net framework 3.5.1 (sp1 patch for net framework 3.5) - but it doesnt seem to do anything on windows 10
Unfortunately nothing seem to help. Do you guys have any idea how to get it to work?
Thanks
