Yeah, it's pretty slick, as long as you're careful not to bend too quickly or with too tight a radius. What I'm not very good at yet is going from A to B and then deciding where to cut it in order for the flare and final length to be right.
https://www.copper.org/applications/aut ... brake.html
#($*@! brake hoses and flare nuts—ideas?
- Has thanked: 987 times
- Been thanked: 1078 times
Can anyone truthfully say they have never made a flare and not remembered to put the nut on first?abscate wrote: 17 Aug 2021, 01:41 Just remember to put the nut on, the right way , before you flare.
You Can bend brake line around any smooth round object of the target bend diameter, no need for the fancy benders they will try have you on.
- Has thanked: 1614 times
- Been thanked: 4078 times
I’ve put the right ones on backwards, the wrong one, a galled one, and left it completely off.
Next day, things went better.
I always try to match fresh nuts with new tubing. But then again, I may just make the flare without any nut.abscate wrote: 17 Aug 2021, 18:46 I’ve put the right ones on backwards, the wrong one, a galled one, and left it completely off.
- 15 Replies
- 2643 Views
Last post by j-dawg
- 12 Replies
- 4591 Views
Last post by theWIFES_S70
- 15 Replies
- 2204 Views
Last post by volvolugnut
- 928 Views
Last post by alschnertz
- 2524 Views
Last post by oragex
