I have started designing my own 3d replacement parts but it's slow going. My ultimate plan in the longrun is to rebuild the dashboard piece by piece.RickHaleParker wrote: 30 Aug 2021, 06:50 At some point the 850 guys will need to do like the 240 guys have already started for the Tupperware parts ... 3D printing.
For control modules ... single board computers. If somebody take the time to reverse engineer them .
If that takes off, maybe Matthew might consider adding a MVS repository for Volvo 3D print files and DIY control modules source code.
It's time to start bulking up on 850s
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Im down, the MCC for the V70 will be the next electrical project id like to start.
2008 S60 2.5T Auto (Sold)
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
I've been stockpiling parts for about a year. I'm glad you're working on the dash, ZionXIX, that and a few other large plastic parts are what worries me the most. The belt style 3D printers which are starting to come into use will really helpful for long parts, like body trim.
The 240 guys blazed the trail, but the larger and more complicated plastic parts on the 850's are going to require us to step things up a bit.
- Has thanked: 2866 times
- Been thanked: 1332 times
What file extension(s) do you work with? I'll open those up to uploading on MVS Forum.ZionXIX wrote: 30 Aug 2021, 14:20 I have started designed my own 3d replacement parts but it's slow going. My ultimate plan in the longun is to rebuild the dashboard piece by piece.
- ZionXIX
So far I'm using a mixture of sketchup and fusion 360.matthew1 wrote: 30 Aug 2021, 15:54What file extension(s) do you work with? I'll open those up to uploading on MVS Forum.ZionXIX wrote: 30 Aug 2021, 14:20 I have started designing my own 3d replacement parts but it's slow going. My ultimate plan in the longrun is to rebuild the dashboard piece by piece.
Sketchup extension .skp
Fusion 360 .f3d
Exported files .stl
- ZionXIX
The biggest problem I'm having is getting accurate measurements on the dashboard pieces. I have junkyard one that has dissolved through 2 moves. I've tried photogrammatry just to have a general shape but it doesn't work very well at all. Those fancy scanners are thousands of dollars. Im almost ready to dedicate a table and built a gantry apparatus where I can take measurements and plot points in a grid fashion until I have the overall shape modeled. It's gonna be a nightmare.
850oldschool
Here's an introduction to the Faro laser 3D scanner:
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 278 times
- Been thanked: 86 times
@toic: agree and disagree (depending on your situation).
I will keep my T5-R as a project car and hopefully soon oldtimer. But I'm getting rid of my s70, as good as sold. Replacing it with a new Kia... Yes I will miss it, but I need a daily driver that I can just put in the shop and have it fixed.
The weather here has been changing a lot the last years, so it is either raining, or unbearably hot. Since I don't have a garage it has become very inconvenient to DIY. This and possible issues with getting parts... were my reasons why.
If I had a garage and space to keep lots of parts then I'd have kept it.
850 T5-R '95 auto
- Clemens
- Has thanked: 501 times
- Been thanked: 228 times
Intersting that you've had trouble finding parts already.hausmeister wrote: 31 Aug 2021, 03:40 @toic: agree and disagree (depending on your situation).
Most things were quite available at my end of town.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- ZionXIX
Yea if money was no object I could buy one but for now I'll have to do things the hard way. I've seen some diy projects for making your own cmm digitizer arm. This totally doable and I should be able to scale it up for later parts. The faro laser looks like a dream come true.
- 559 Views
Last post by a1jon
- 1271 Views
Last post by readallthebooks
- 31 Replies
- 6169 Views
Last post by Sveedy
- 243 Views
Last post by V50M66
- 356 Views
Last post by jreed
