Slower than Grandpa! How to recover my performance?
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Maybe the points are arced? Bad condenser?
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Before you start throwing more parts at it, take some vital signs like compression. Smoke test the intake system.
Cylinders maybe getting carbonized. I posted many times on how to remove the carbon with a Seafoam soak.
How old are the Fuel Injectors and O2 sensors? The two can degrade performance without any other symptoms or DTCs. I would go after Injectors before O2 sensors.
It could be a clog in the exhaust system. When was the last time the resonator of muffler where replaced? You can check for a clog in the exhaust system by removing the front O2 sensor. If it runs much better there is probably a clog in the exhaust system. Don't be quick to blame the Catalytic converter. It could be the resonator or muffler.
Active
Past
RickHaleParker
scot850 wrote: 17 Dec 2021, 11:42 Erik have you been on the eggnog again? :D It is a 2000 MY = No distributor!!
Your hard to please. Erik gave you a Grandpa answer to a Grandpa question.
Active
Past
RickHaleParker
erikv11 wrote: 17 Dec 2021, 23:09 Maybe the points are arced? Bad condenser?
It's a European car, probably some stole away Gremlins that grew up. πŸ€”
Scott call +1-212-897-1964. ( 1-212-NO-GHOST ). :wink:
Active
Past
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
I like the idea of a trans service as an inexpensive needed anyway place to start.
