1996 850 engine revs without accelerating or shifting gears Topic is solved
EB53
- Year and Model: 2013 XC60
- Been thanked: 3 times
New piece of information. Was out driving and engine started revving to 3000 at 15 mph. If I jiggle the gear shift lever while in drive, without shifting to 3rd, the RPMs dropped to 2000 and I was able to accelerate normally. Even small movement of the gear shift while in drive, is enough to bring RPMs down. Does this suggest that the lockplate for gear shift is loose? Any other thoughts? Thanks.
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
There were two times i have had this issue with two separate causes. One was caused during normal driving and it was due to the transmission fluid being too low after a drain and fill. It would drive perfectly normally but at times you would push the petal and it would rev but do nothing. Filling the fluid to the proper levels fixed that.
A second time occurred when my ignition coil went out on the highway although the car died and i replaced the ignition coil.
Suffice to say it does sound like a transmission issue although it might just be fluid.
2008 S60 2.5T Auto (Sold)
EB53
Thanks. Transmission fluid is near top line in reservoir. and fluid is clear on dipstick. Car doesn't die, so probably not ignition coil. I agree it is likely a t'mission issue. Really just takes small jiggle of shift lever for RPMs to drop back to 2000.
EB53
For those who followed this discussion, the problem has been fixed. Turned out the PNP switch was not working properly. Replacing the switch returned the engine to normal acceleration. It wasn't a problem with the throttle body, throttle position sensor, or transmission fluid levels, none of which fixed the problem when addressed. There never were any codes nor did check engine light come on. Thanks for the various suggestions.
- Has thanked: 1611 times
- Been thanked: 4071 times
Thanks for follow up post!
- Has thanked: 2207 times
Glad you found your solution! Well done!
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
Since the exact same thing happened to me today as well, I might give that a try
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 1789 Views
Last post by MadeInJapan
- 3266 Views
Last post by Steve99s70t5manual
- 645 Views
Last post by MoVolvos
- 18 Replies
- 2559 Views
- 942 Views
