To sum up
-High fuel pressure seen at startup.
-Efficiency code which might be slow secondary O2 on bank 2. Sounds to me like the heating element is broken and relying on exhaust heat, but can still read O2.
-Rich on both banks
-Smoke test didn't show any leaks
FPR, MAF, and PCV were done
Thats, the current info? Yeah, live graph behavior could help to see when the primaries are picking up the rich condition, like if it's all rpms, on load, higher rpms, etc.
IIRC, you can check the fuel pressure manually with a gauge (edited). On the opposite side of the FPR on the end of the rail, there is a plastic cover that unscrews to reveal the schrader valve.
Running rich (both banks) 3.2
chitownV
- Year and Model: 2008 XC90 3.2
- Has thanked: 15 times
- Been thanked: 40 times
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
The high pressure at startup is by design.Holcombehas6 wrote: 02 Mar 2022, 05:14 And fuel pressure seemed to be too high at startup. Like 72 psi.
The extra pressure allows for better atomization of the cold fuel.
For my LR2 3.2 the pressure stays high (61 PSI) until after the ECU switches from a high idle to a low idle. I think that it drops to 55 PSI in less than 30 seconds from the starter turning.
I can find the section in the Land Rover Shop manual that describes this if you want more information.
Thanks
Paul
- pgill
I am not sure based on your post if you have a:Holcombehas6 wrote: 02 Mar 2022, 05:10
Replaced MAF, PCV, fuel pressure sensor on the rail
Lean conditions bank one and two.
Vacuum leak (unmetered air)
or
Excess fuel.
The fuel trim will tell you this
Positive Long Term Fuel Trim = Vacuum leak / unmetered air entering the system
Negative Long Term Fuel Trim = extra fuel entering the engine (the purge valve could do this)
Lets assume that you engine is Running Lean due to a Vacuum leak / Unmetered air and it is Adjusting the fuel trim to add fuel (Rich adjustment)
For a running Lean due to a Vacuum leak I would check the following
1. The six intake manifold gaskets could fail which would create a vacuum leak
2. The gaskets for the intake runners (there are 2) could fail and create a vacuum leak
3. The gasket at the throttle valve could fail and create a vacuum leak
4. The small hose from the purge valve could fail and create a vacuum leak
5. The intake tube has a sound attenuating box that can leak. This is technically unmetered air and not a vacuum leak. If you disconnect the MAF and just use the MAP to run the engine and the LTFT gets back to normal then this is where I would look.
Intake Manifold gasket (Intake runner and Throttle are similar but larger)
Purge Valve Hose (small hose between Valve and manifold is under Vacuum at idle)
Intake tube sound attenuator boxes (if the box or seal fail it will allow for unmetered air to enter the engine) ignore the arrows they are point at the clamps the hold the intake tube to the the throttle body and the air box
Good luck
Paul
chitownV
Paul, that's a lot of good info. I believe Holcombehas6 had a smoke test done to check for vacuum and intake leaks. None found.
- 5652 Views
Last post by chrisjm91
- 18 Replies
- 4360 Views
- 17 Replies
- 3501 Views
Last post by John850GLT
- 814 Views
Last post by misha
- 29 Replies
- 4508 Views
Last post by misha
