how can a straight six have 2 banks?
chrisjm91
Year and Model: 95 Volvo 850T5
Post by chrisjm91 »
I have a straight six here with a PO171 lean on bank 1 & PO174 lean on bank 2, and cylinder 4 misfire. I thought only "V" type engines had banks? I raise the rpms and long term fuel trim goes up with it And sitting at idle in parks its reading a 30% load.
bskeels
Year and Model: 1997 Volvo 960
Been thanked: 3 times
Post by bskeels »
Typically the bank 1 is the upstream oxygen sensor (before convertor) and the bank 2 is down stream (after convertor), codes for the "V" type engines will state "bank 1 sensor 1 or 2" for upstream and "bank 2 sensor 1 or 2" for a downstream code
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
That 6th cylinder could be a problem since your sig indicates an 850 T5.
:D
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
What car is this for?
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
When the engine has two or more front (upstream) catalysts and fuel trim has to be controlled for the groups of cylinders feeding each catalyst, the cylinder groups are known as Bank 1, bank 2, bank 3, etc.
The naming was originally used for V8 and V6 engines where the exhaust manifolds for each side, or bank, had its own oxygen sensor and fuel trim was controlled bank by bank so the catalyst on each side would work best. For in line 6 cylinders it is very common. Cylinders 1,2, and 3 are bank 1 and cylinders 4, 5, and 6 are bank 2. Volvo 6 cylinders from '99 are this way.
Some V12's are 4 banks due to using two separate 6 cylinder engine control modules and 4 upstream catalysts.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Ozark Lee wrote:That 6th cylinder could be a problem since your sig indicates an 850 T5.
:D
:mrgreen: :mrgreen: :mrgreen:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
chrisjm91
Post by chrisjm91 »
Thanks for clearing this up for me. Like I said, I thought banks were "sides" of the engine for "V" type engines. But with a straight engine like a straight 6, using 1-3 as bank 1 and 4-6 as bank 2 makes sense.
