Running rich (both banks) 3.2
Holcombehas6
Year and Model: 2012 XC90
Post by Holcombehas6 »
Good morning from Georgia everyone. I currently have 3 Volvo’s all of them have the 3.2. My wife has a 2012. We have rich codes across both banks. Not just one. As far as I can tell, I’ve replaced every sensor known to man short of the O2 sensors. They both work fine except one (bank 2) is slow to warm up, then shows fine. It will be smoke tested on Monday. Anyone have any suggestions as to what I could be missing???? It runs fine short of a random thing that happens when it is started. It feels as if it doesn’t get enough fuel, then after 3-5 seconds it’s fine. It does have some oil consumption like some of these engines do. Would that play into the rich conditions??? About a month ago, the CEL randomly went off, and my wife took it to get emissions done and it passed. Two hours later it was back on. Everyone is at a loss here. Thanks
Turbo_Boss
Year and Model: 2008 XC90 3.2AWD
Has thanked: 12 times
Been thanked: 2 times
Post by Turbo_Boss »
Hi Holcombehas6
What are the codes you have?
What year and mileage is your 3.2
Rgds
2008 VOLVO XC90 3.2L AWD
2008 TOYOTA Prado 2.7L 4x4
2009 VW Jetta 2.0
chitownV
Has thanked: 15 times
Been thanked: 40 times
Post by chitownV »
Agree with Turbo_Boss' questions.
Interested to hear about the smoke test as a vacuum or intake leak could affect both banks.
Cheers
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 120 times
Been thanked: 189 times
Post by pgill »
Here is what I would do in your situation.
1. Check the pressure at the fuel rail. You can measure it independently with a pressure gauge (which is a bit challenging) or swap the sensor between two of your 3.2s. I own two 3.2s and I would swap the sensor or replace it. Why? if the sensor is measuring the wrong pressure then it might convince the ECU to run the fuel pump too much which will give you a rich running condition.
2. Verify that the Voltage drop with the engine running is about 0.050 Volts between the cylinder head and Battery negative. Confirm this on your other 3.2 to make sure that you are measuring correctly. (A bad ground can cause significant problems like the one that you are suffering from)
3. Check the fuel trim what is the LTFT?
4. The Vapor recovery purge valve can fail and that would let large amounts of fuel into the intake manifold. A LR2 owner with the Volvo 3.2 recently had a purge valve failure (but the check engine light was for a evaporative emissions leak not fuel in the intake) The purge valve has a small hose connected to it, I would pinch that hose or remove it and temporarily plug it.
5. The MAF could be broken. Disconnect the MAF and run the engine without it. Does this help with the Fuel trim?
6. This last suggestion is only for the brave of heart. To confirm that the ECU can't control the mixture correctly add extra fuel to the intake air (Propane will work) if you do this the ECU should reduce the PWM (Duty Cycle) of the injectors and the Fuel Trim will be negative.
7. I lied I have one more. Remove the electrical connection to an injector and watch the misfire counts. If the purge valve is allowing fuel into the intake then the cylinder will likely continue to fire.
Note: the ECU will only allow the Fuel Trim to be adjusted by a certain amount and then it will stop adjusting.
Good luck
Paul
2010 S80 3.2
2008 LR2 3.2
pgill
Post by pgill »
One last thought
I did this recently for a LR2 owner with the 3.2
You should confirm that your 3.2 does this (if you don't have a code reader that can give you this information then you should get one)
I am going to quote myself
I did a cold start today.
0 PSI before I engaged the starter motor
On initial startup the fuel pressure spiked to 69 PSI
Then it dropped almost instantly 61 PSI
The interesting thing to note is that the RPM dropped to ~800 RPM before the fuel pressure dropped.
It took a few seconds for the pressure to drop to 55 PSI
The RPM drop seems to be attributed to the Throttle position
14.1% --> high idle
3.5% --> low idle
High Idle
here is the link
https://www.freel2.com/forum/topic37689-15.html
good luck
Paul
chitownV
Post by chitownV »
The OP hasn't responded after more than 2 weeks. Wonder what his CEL was.
Holcombehas6
Sorry for the delayed response everyone. So smoke test, nothing. Completely clear. Mileage is 142k. Replaced MAF, PCV, fuel pressure sensor on the rail (no way to check pressure on the rail), and that’s it. Lean conditions bank one and two.
Holcombehas6
Codes were 0172 and 0175. I also had a 0420 code for bank 2 only. I’m going to attempt to put a picture of the O2 sensors on here. They said the bank 2 rear was “slow to respond” but was running correctly once it warmed up.
Holcombehas6
And fuel pressure seemed to be too high at startup. Like 72 psi.
Holcombehas6
