454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
scot850 wrote: 03 May 2024, 18:09 TYC stuff is ok. I would not think twice about using their lights.
Same here. I've used TYC for several vehicles. I'm not sure who, but I believe they are an OEM for a few automakers.
The TYC headlights I bought for my Saturn had an awful light pattern, but they worked for my purposes, and everything else Ive bought from them has been much better..... S70 headlights and turnsignals, Chevy headlights, tails, and front signals and reflectors. I'm disappointed they don't seem to make headights for the 850 (anymore).
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1611 times
Been thanked: 4075 times
I found the left TyC headlight worked well but my right TYC failed after only three months.
There was no documentation saying it could not be used to push a Tesla at 30 mph, so I don’t think it was my fault.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
abscate wrote: 04 May 2024, 06:12 I found the left TyC headlight worked well but my right TYC failed after only three months.
Not yet... but now they're going to have to add that to their product description.
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 116 times
Post by Goupil »
Easy job this morning :)
Did check the LH axle, both my spare and the one on the car have play on the gearbox side joint but none on the wheel side, odd...and it's the opposite on the RH axle !
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
454cid
Post by 454cid »
Worked on my side lights, fender trim, replaced the oil filler cap gasket, and fiddled with the windshield washers.
I also went to the auction house, and briefly looked at more Volvos and other vehicles. They've got a couple S40s that are possibilities, and also an S60. I also saw a Suburban with a 454 :-)
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Took the Silver Kat for a one mile commute to spend the evening with Itzkak Perlman.
duke1
Year and Model: 855 1994 10v
Has thanked: 416 times
Been thanked: 34 times
Post by duke1 »
hi all well today i fitted the new rear handbrake shoes and sorted out the rear calipers with a good clean and cleaned the drum and adjuster all is good nick and functions as it should,the reason for the delaminated lining was entirely obvious being the retainer rusted out and shoes sitting at the wrong angle and dragging the edge all the time must get superhot and undo the glue,also some jerk has changed just one side shoes previously as one side was volvo other after market type,why? lazy thats why.
besides that i am just awaiting a new set of rear brake pads and fitting kit being i hope the last expense for a while as it is rather a lot of outgoing cash,money pits is right!but i do still love the car,just want to drive it now back at goodwood motor circuit,,,,,,,later on i am going to do an entire list with costings of all the work ihave carried out and the cost saving of doing the work myself versus garage cost for the same work,first will shock me im sure and 2nd may lessen the shock some!cheers all
Has thanked: 2212 times
Been thanked: 1852 times
Oh no it won't! Been there and done that. There is no such thing as a cheap old car. Not even with a Volvo. It is even worse over here as we have no MOT so owners run cars until they barely work and sell them. As Volvos are usually good at running while broken they usually have a list of issues to repair.
454cid
Post by 454cid »
I checked my air filter today and found that it was still the filter that was installed previous to my ownership. I've had the car two years. I thought I had changed it, but that must have been the S70, or I'm thinking of the HVAC filter install. It still looks okay, so I put it back.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
I used to be totally up on my car maintenance, even when we had 4 or 5 cars being used. But now we are down to 3 (and one only used 6 months a year), I find it harder to remember. I just went to the Toyota dealer to get the service documents they were supposed to give me. Part of the purchase was all servicing to be brought up to date as they told me the car had a full service history. It didn't. Again I had suspicions that they had change the trans fluid but not the filter. Sure enough that is the case. They also only changes one wheel bearing and not both. I'm hoping to do 2 longer runs of 3400km and 2200km this year (about my annual mileage) so I want everything up to date.
Thanks for the reminder as the R has a K&N filter and I could not tell you when it was last cleaned. In my defense the car has only done about 10000 miles in 12 years, but with so many forest fires it could probably do with a clean!
All 3 cars need an annual oil change, although all run synthetic and have only done 6000km and the R 500km!
