hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
abscate wrote: 10 Aug 2024, 07:45 There is a thin metal gasket there. Probably aftermarket only. I will look in my stash at home in a few days.
When I replaced the exhaust: no gasket on turbo outlet, but I had a metal gasket part 26 in the pic that should go after the manifold. I damaged mine while installing and left it off. Would always bind up somehow and I gave up.
850 T5-R '95 auto Image
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
In the P80s and early P2s I've worked on, I have never encountered one with a gasket between the turbo and down pipe. I too was confused about it at first, but the more reading I did I realized it was normal. And I haven't seen them leaking enough to hear/smell/feel.
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Bit of tinkering today and painted the 6 Torx bolts that hold the plug-lead cover in place. Not sure why I never done it sooner as I did the V70 ones last year
I collected my Volvo sign from the powder coater yesterday, he tried 3 times to apply two colours but had trouble getting a crisp line so gave me it back in silver and I sprayed some blue onto it today, I also had trouble with the line but once the paint has hardened I should manage to remove any blemished with some thinners
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Has thanked: 1836 times
Been thanked: 1709 times
I have had a look at the parts drawings again at higher magnification, and it now looks clear as hausmeister and Bdub have clarified, there is no gasket between the turbo and the downpipe to the cat. It looks more like a cup and seat type seal. If you had issues with worn or pitted surfaces, a little gasket sealer should fix that.
Thanks to you guys for helping clear that up!
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 28 times
Post by RedBrickCollector »
Fuel pressure regulator finally and along with it I got a new thermostat and thermostathousing gasket (water marks visible on mine).
Thing is I can't see a simple way to tackle the thermostat housing. Pull the P/S pump aside? Remove the alternator? Seems near impossible to acces the bottom bolts.
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
P80GLT
Post by P80GLT »
Attended the Dumfries Motor Show today and was the only Volvo there
The clock turned over 64,000 miles on the road home this evening
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
scot850 wrote: 10 Aug 2024, 12:39 I have had a look at the parts drawings again at higher magnification, and it now looks clear as hausmeister and Bdub have clarified, there is no gasket between the turbo and the downpipe to the cat. It looks more like a cup and seat type seal. If you had issues with worn or pitted surfaces, a little gasket sealer should fix that.
Late to the chat, but there *is* a gasket available for the angle-flange turbos (maybe even the straight flange ones too).
I have one on both of our cars (16T angle flanges to 3" DP).
Was there one from the factory? I dunno. These cars are WAY past that point.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 999 times
Post by volvolugnut »
P80GLT wrote: 11 Aug 2024, 15:55
Is 80 MPH legal on the Motorway?
It is legal as long as you don't get caught! :roll: :lol: :lol:
There is a gasket on the FWD cars, but not on the AWD from what I can see. But interesting that there may be another option.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
[quote
[/quote]
Nice bit of shop art ! :)
1999 V70 GLT
