ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 27 times
Been thanked: 33 times
Post by ndphotonl »
oragex wrote: 19 Mar 2020, 17:35
ndphotonl wrote: 12 Mar 2020, 13:15 Changed the control arms & ball joints not too long ago.
Hopefully those are good brands. We can see the fight on the metal where the ball joint sits.
Do you mean the chafing in the "cup", or the indentations on the ridge?
The indentations are from me, trying to get the ball joint out. it was flush when I started the job :)
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Active
Past
Cookie-the-Swede
Year and Model: 2003 S60 2.5T AWD
Has thanked: 1 time
Been thanked: 4 times
Post by Cookie-the-Swede »
I replaced my radiator and thermostat.
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Mounted the summer tires for the 04' and 05'
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
ndphotonl
Post by ndphotonl »
Looks good :)
FlickR images
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
850 LPT wrote: 22 Mar 2020, 15:19 Mounted the summer tires for the 04' and 05'
Boy the tan one is in good shape (I have the same thing, but slick top & auto AWD, and not as nice). Way to go! To you and your daughter. Is it T5? Nice job to both of you on keeping the Thor's away from curbs :) Mine have encountered many curbs.
I did nothing Volvo task-related today, but did enjoy the new sounds reverberating from the tailpipe of our 284k XC70.
Catted this time
Catted this time
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
ndphotonl
Post by ndphotonl »
Enjoy the added power & sounds :)
I replaced the coil packs with SKV coil packs (after 205k miles), German quality (whatever that is worth) :)
ImageVolvo S80 2.4T New SKV Coil Packs by Andy Ramdin, on Flickr
Also had an alignment done after replacing the control arms. Tracking was way off, which has been sorted. Also got my "new" wheels balanced, which was needed. Drives like a dream again!
ImageVolvo S80 2.4T Alignment @ Daemen Banden Service Venray by Andy Ramdin, on Flickr
FlickR images
ragnarthevolvo
Year and Model: 2002 V70 XC
Post by ragnarthevolvo »
I added a little Swedish flare in the engine bay. Blue and gold on the wiper fluid cap. Coloring “Volvo” yellow on the spark plug cover. Thinking of going for a full Swedish flag on the spark plug cover...
IMG_9478.MOV
Swedish colors in the engine bay
(3.09 MiB) Downloaded 185 times
- Pete -
Post by - Pete - »
ndphotonl wrote: 27 Mar 2020, 09:00 Enjoy the added power & sounds :)
Oh I have been, for a while now. That’s not the first DP for me. Lovely music coming from behind & minimal drone with the resonator delete on the adapted/harvested part-out R-exhaust.
Hey Andy, can you post a link for those coils?
I was able to find some from a Polish seller, but was unsure of the listing. I always enjoy your photos! Thank you for taking the time to snap them. I perpetually fail to do so. Usually because my gloves/hands are greasy. Please continue posting images.
“Dan”, as our 4-year old calls it (04 V70AWD), got a present today. If anyone has questions about this DP, let me know.
Of the different DP’s I’ve purchased & installed, this is by far thee nicest. I’m talking welds, material, gaskets, packing, versatility of a 3-piece DP, quick response time with EuroSport tuning staff/owners...I’m truly impressed. This absolutely blows the Snabb & RE-VOLVO catted or catless DP’s out of the water.
3 bungs (you’ll need a plug if you’re not running a wideband), perfect TIG welds, true (and beautiful) T304 SS pipe, v-bands, flanges, everything. This is a very inexpensive system & they ship it same day. Not waiting for the welder to jig & fabricate the system. I ordered this Tuesday, shipped same day from Ontario, delivered & installed it today (Friday). Ahh-mazing.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Installed these yesterday.
IPD Poly Front Subframe Bushing Insert Kit - 3507923
https://www.ipdusa.com/products/8969/12 ... 68-3507923
Genuine Volvo - Subframe Bushing Washer - P80 P2 S60 S80 V70 XC70 XC90 - 31329447
https://www.ipdusa.com/products/8859/12 ... o-31329447
MTC - Subframe Bushing Bolt - 985111
https://www.ipdusa.com/products/20815/2 ... 1453,P8283
MTC - Subframe O-Ring - 8638585 - Purchased MTC but Volvo's O-Ring link describes purpose of part
https://www.ipdusa.com/products/8283/11 ... 283,P20815
Was able to use the old bolts, metal washer / plate and the impact to drive the inserts in. The rear driver's side insert needed a socket extension with a jack underneath to more precisely push / squeeze it in. Probably a newer bushing. I also sprayed the subframe bushings generously with the AT-205 and it made the job harder as the rubber surfaces were rejuvenated.
If I had to do this over I would start by loosing all 4 bolts and do the insert on the driver's side rear bushing first. There is a guide pin (last photo borrowed from Swede Speed - Link Also) which the other 3 did not have. With the other 3 done first the subframe was tight and I could not flex it down enough for the O-Ring to go over the guide so had to loosen the rear passenger side again to allow the entire rear subframe to come down far enough with a large pry bar. Maybe this is why in IPD's video they show doing the driver's side first :?
Subframe 2.jpg (63.31 KiB) Viewed 1507 times
Subframe 3.jpg (19.86 KiB) Viewed 1507 times
Subframe Guide.jpg (7.59 KiB) Viewed 1507 times
https://forums.swedespeed.com/showthrea ... read/page4
